fair do's, exact same setup as on landrover (even the oil catcher and drain)
i think i got a bum steer as someone previously said the leather seal had been superceded with neoprene version. it looked like you got both types of seal for same application
Last Edit: Aug 2, 2018 16:05:39 GMT by darrenh
Tamber
Shattered. Held together by spite and tape.
I'm a long way off using it yet, unfortunately. The list of stuff I have to do is unpleasantly large, and only shrinks very very slowly. (My cab was only held on by wishful thinking and rust, for example, and it's taken me a few months to get it to the point there's actually real metal for the rear cab mount to hold on to.)
-< Welder. Allegedly a mechanic. Bodger of Things >- * 1958? Bedford RL - Progress: Glacial. * 1994 Skoda Favorit - It's baaaaaaaack! * 2018 Herald Classic - Off the road, indefinitely.
Tamber
fair do's, exact same setup as on landrover (even the oil catcher and drain) i think i got a bum steer as someone previously said the leather seal had been superceded with neoprene version. it looked like you got both types of seal for same application I think that's probably down to the lack of context for the size of the various seals. The outer in this picture is the neoprene tracta joint seal, the inner is the modern hub seal. The carpet is... well, it's the carpet. (I would like to thank whoever linked the xmod page for the tracta joint seals; I was having a curse word of a time finding them until then. Still, my reading comprehension wasn't great, because I only got half as many of the seal springs as I needed. Ho-hum. )
Last Edit: Aug 2, 2018 16:29:44 GMT by Tamber
good comparison, thanks Tamber
Frankenhealey
Club RR Member Number: 15
I'm a long way off using it yet, unfortunately. The list of stuff I have to do is unpleasantly large, and only shrinks very very slowly. (My cab was only held on by wishful thinking and rust, for example, and it's taken me a few months to get it to the point there's actually real metal for the rear cab mount to hold on to.) We need a restoration thread and pictures for this!
Tamber
Frankenhealey
Just trying to arrange another MOT and a racing friend sends me this to show to the DVSA tester
Frankenhealey
Aug 24, 2018 14:21:33 GMT
New modern seals arrived thanks to Tamber Dangerous can't start before the 10th September due to prior commitments and I'm still waiting for Debbie from ETS Trucks to confirm the MOT date. It will be after I get back from Malta and let's hope we get Mr. Bray again because it will short circuit half an hour of "you can't test that 'cos it doesn't have it/one". Horrible side reflector/markers ordered because they're cheap and I can sort something out more period over the winter, I hope So while I was waiting I came up with a few safety signs for the rear. Being a special truck they needed to be a bit special themselves This is my number two fear after the nightmare of some tw@t cutting into my carefully hoarded braking distance. The next two might be a bit intellectual Other suggestions welcome
Aug 24, 2018 14:32:29 GMT
Sign one; I'd have "Suicide" on both arrows. Sign three; does anyone do physics any more? Or will you need a huge one explaining Newtons Laws all over it? "Back off or die"? and for the front, "By the time you read this, you will have been reduced to your lowest molecular level"? No, then we'd need another explanation sign. "We painted this blood red for a reason!" Applicable anywhere. Leave 'em in no doubt. That's my view.
Last Edit: Aug 24, 2018 14:33:40 GMT by georgeb
Phil H
Club RR Member Number: 133
Aug 24, 2018 14:36:02 GMT
“Caution - this vehicle may stop gracefully”?
Phil H
Aug 24, 2018 14:38:45 GMT
“The car in front is...my crumple zone”
“I know it’s big enough to have it’s own gravitational force but that doesn’t mean you have to get so close”
Phil H
Aug 24, 2018 14:40:10 GMT
“Caution - carried vehicle may be fitted with a quick release hitch. Keep your distance.”
Aug 24, 2018 14:53:09 GMT
Aug 24, 2018 17:39:26 GMT
We could'nt fix the brakes, so we made the horns louder
I brake subjectively
In order to remain in superposition, please stay back 500ft
Thought experiment requirement stay back 500ft
If you can read this,you risk being schrodinger's cat, not an observer
be the observer, not the cat stay back 500ft.
eternaloptimist
Aug 24, 2018 18:21:37 GMT
Caution Driver wearing hat
Aug 24, 2018 18:50:48 GMT
Land Rover recovery vehicle.
Aug 24, 2018 19:39:33 GMT
Caution. Maintained by Dangerous Enterprises ltd.
Aug 25, 2018 10:52:42 GMT
just attach brushes to the wheels to sweep up the mushy ex-cyclist residue , its only the process of natural selection in action!
adam73bgt
Club RR Member Number: 58
Aug 25, 2018 15:50:42 GMT
“Caution - this vehicle may stop gracefully”? **“Caution - this vehicle may stop... eventually”?
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
*****Caution, this vehicle *may* stop.
