My bmx bus/car/van (Nissan Serena) , is bogging down badly under throttle.
I know to check the air intake for splits/leaks , and will replace plugs and leads.
it's had a new distributor cap and fuel filter
what else should I check for? MAF?
it seems that sometimes it'll pull well, and other times it'll really bog down and feel like it's going to stall.
It's an SR20De if that helps
It's very intermittent, so I'm hoping plugs and leads will do the trick but any advice welcomed
