got a mk 2 polo engine here , I'm cleaning it up ready to swap over
its a budget job , i havent got money to waste.ive stripped the valves out the head and id like to gather some idea on the condition of the valve guides
any ideas ? as its either clean up this used unknow head , or use the 180k one thats on the car that doesnt use oil
Put a valve back in and see if there is any play in it. IIRC if there's enough movement to feel it they're worn.
Matt
is this a normal amount of flith to expect?
PhoenixCapri
West Midlands
Club RR Member Number: 91
Hmm maybe a bit more than you'd expect, but if its done a lot of miles, or has been running a bit rich for a while, its not that abnormal. To be honest if its been burning a little oil the stem seals were probably the issue, and the guides should be fine for a good long while (I've never actually replaced any yet!)
hmm instresting youve not replaced any
I'm scared of spending what little money i have on this if it turns out to be a oil burner , the one on the car isnt using oil
in your experiance do the valves slop around in the guides much?
RetroMat
Column Shifting!
grind the valves fit new stem seals should be good to go! My madza had that amount of sludge on the valves and that had only done 60k
hard to know what to do ...some folk are saying its prob well worn
Just check for side to side play by putting a valve back in and wiggling it. If you can feel it moving its worn.
Matt
