Aug 26, 2010 18:48:54 GMT
I think 40 bhp on that boat is not OTT, how long was it again?
My old black and white simms ran a 33hp Johnsons (older than yours) and was 14ft long. It was quick but perfectly stable.
What angle is the transom at in relation to the bottom of the boat. If the boat wants to nose up once on the plane, make the engine 'point down' by a few degrees. that will help to push the bow of the boat down and stop porpoising.
Have you got and far shots of the boat giving a sense of scale?
What is the transom made from? what thickness is the timber or ply?
Sorry for the questions, but it looks fine to me, but filling in some of these questions will give us a better idea of if there might be any potential issues.
Lewis
Aug 26, 2010 18:52:30 GMT
Well I have just looked at the pics again, and it looks fine to me.
I would say you will get about 30 - 40 mph out of it flat out which is plenty fast enough.
Just make sure the transom and fixings are all in good condition etc. Take it out for a few low power runs to get used to it. You can't do more than 5 mph on the river anyway. Get down to a local watersports lake and go for a blast, but do a few short runs, then bring the boat back and check for any signs of deterioration of the transom.
Lewis
Fungus
Aug 26, 2010 18:58:23 GMT
Tbh, i think 40bhp is just right on that boat, so get it moving along nicely. We just sold a 15ft fletcher with a merc 90 2 stroke, that was a bit of a handful but the only reason it had suck a big engine was becasue we use towables too. As lewis said, that angle of the motor is important too
Aug 26, 2010 19:08:37 GMT
ahh wicked. cheers for all the info guys Tis nice to have some sensible answers.. if i ask these things on boat forums i get met with the usual "you should allready know" type attitudes..... Ill get some more decent pics of it... Any luck and ill pull it out of the garage tommorow I wanna see how big this johnson looks on it haha
Aug 26, 2010 19:40:14 GMT
Also, you might see (and already done this) but the transom clamp will have some bolt holes in it (well it should).
Clamp the engine on vertically plump and on the centre line of the boat then drill and bolt the thing on with some bit bolts and nyloc nuts. That will make sure that if the clamps vibrate loose you don't lose the engine (which would be bad).
You might find that the boat torque rotates under full power. you can reduce this by setting the motor off centre by a few centimeters. Line it up central to start with, then go from there.
Waveman - I bet that fletcher was a handful. dread to think how fast that went flat out on calm water. Backflip tastic.
Lewis
Aug 26, 2010 20:37:24 GMT
ahhhh muchos wicked mate cheers all very very cool advice I'm gonna get a lil gorilla pod for my camera for the trial run and see how she goes Ill get a vid up haha...
Fungus
Aug 26, 2010 21:00:52 GMT
Waveman ?? I reckon that should actaully be my name :L Yep, accross rhoscoyln bay flat out, luckily it had power tilt/trim, but we still managed to break the seat on impact :L:L Not as bad as our old boat, it was a flat bottomed dory with a johnson 80, not great through the waves
Aug 26, 2010 21:02:37 GMT
Woops, I meant Hondaman.
There is a chap on here called waveman with boats though. Fingures faster than brain.
Lewis
Aug 26, 2010 21:11:22 GMT
Oh and also, you can put a padlock though the two screw motor clamps. If you look at them the have a hole in the end. Clamp the motor on, line them up and then put a padlock though them. Saves the engine being pinched, and should stop the clamps losening off.
Lewis
Aug 26, 2010 23:03:46 GMT
ever thought of giving advice on boats as a profession? seems you could make some decent money out of it
Aug 27, 2010 11:12:47 GMT
Surely if it's too fast you just don't use full throttle?
Matt
Aug 27, 2010 13:35:35 GMT
i allways thought that too. but from what people have said its not that easy... although without trying i wouldnt know.
Fungus
Aug 27, 2010 14:24:51 GMT
Up in anglesey there were a load of motors stolen this year, we paddlocked ours so they took the bloody petrol tank Make sure those clamps are REALLY tight, my mate managed to drop our brand new 2.5hp merc off the dingy last year
Last Edit: Aug 27, 2010 14:27:48 GMT by Fungus
Aug 27, 2010 14:50:05 GMT
Oh i will I'm gonna watch dog the bounty hunter quick then I'm off to fit the new impeller as it turned up yesterday.. , Turned out to be hard to find as its a slim model they only fitted between 73 and 76 on certain 35/40 hp engines... got it tho and its spot on original johnson...
Fungus
Aug 27, 2010 15:53:26 GMT
Sounds good, let us know how installing it goes
Aug 28, 2010 17:59:06 GMT
FITTED I'm gonna get some more pics up tonight i hope... Put it in the drive and took some better pics and some of it with the engine on for a scale type thing....
Aug 29, 2010 11:55:02 GMT
Hmmmm, well the rear seat out of my dads bug fits it sortaItll need the base chopping slightly but thats not a problem as doing that will give me the original shape (up against edges) But be soft enough for it to pull out of the boat without dismantleing it. I'm going to make a support frame for it to hold it in one piece instead of two peices. Then a simple fitting at the front to allow it to be removed easily should the need arrise. And then its going to be recovered by a marine upholstery place my dad is friendly with ;D And some pics to give the boat a scale....
Aug 29, 2010 12:57:23 GMT
that engine looks perfect on there and the boat looks great overall.
Aug 29, 2010 14:04:48 GMT
Phooooaaaarrrrrrrr!
skinnylew
Club RR Member Number: 11
Aug 29, 2010 16:13:31 GMT
nice pics with the DS and beetle
