carmad
Oct 29, 2010 18:05:13 GMT
If you read the thread I said it's got an omega gear box
Which is massive compaired to a ford type 9
to be honest you would be better looking at my ha saloon that rybukku built
Even tho it's a 2.0 it has a ford box
carmad
Oct 29, 2010 18:11:29 GMT
Oct 29, 2010 20:27:46 GMT
this is truly inspiring, love the cobbled together lump just an idea for the paint, why not copy the current scheme? I think it's awesome I second that!
lotdave
only one gerry
Oct 29, 2010 21:03:53 GMT
hi mate the reason i asked about blower possition is only because ive mounted mine on a home made plenum as you have seen. I guess you plan to pipe around the bay ? I'm not doubting your work fella just curious, i love the old ha vans i had one back in the day for work and would have one now if space was'nt an issue good work mate ;D
lotdave
only one gerry
Oct 29, 2010 21:05:12 GMT
Wish i knew how to make my pics smaller
carmad
Yes I was hopeing to be able to pipe it up
couple of reasons
I can take it off if it doesn't work
I wouldn't be confident that my welding would be air tight
I wouldn't have a clue how to make a plenium
It allows me to pipe in a intercooler
What ecu ect are you running ?
carmad
Oct 30, 2010 17:08:03 GMT
started today by modifiying the head for the supercharger bracket that i started last week i had to drill 2 parts out on the head that would usually mount a heat sheild so drilled them and tapped them out for a 13 mm bolt next up was the thermostat houseing opened it up then i shot blasted it new thermostat in bolted up with new cold start sensor and temp swith for the dash next up a flat belt altinator from a x20xev as this will allow my supercharger belt to sit straight i spent most off the day stripping it and cleaning it tho i didnt take many pics here it is finished and on the engine next up is a standard c20let top hat then shot blasted and on the engine more soon
carmad
Oct 30, 2010 18:15:38 GMT
next up is a small panel that goes behind the dash under the bonnet that the heater matrix hoses go threw sandblasted primered painted and like my viva hc parts now wrapped up and in storage waiting to be put on the car
lotdave
only one gerry
Oct 30, 2010 20:10:49 GMT
;D ;D ;D Your loving that new toy of yours "i want one" ive got loads of bits in need of blasting. that engine is looking so sexy You asked what ecu I'm using ive got a guy building me a mega squirt I'm getting the ecu, fuse & relay box, lead between the two,engine loom, Pc lead and software and an engine simulator all for about £600 bargain i thought ;D
carmad
Oct 30, 2010 20:30:11 GMT
sand blaster is the job so much time saved
was toying with the stand alone ecu ill wait and see how my vxr hc omes on
carmad
carmad
Cheers mate cool pics is that charge pipe plastic or painted yellow ?
That was a bit of a sore point, I had it made to my spec, but the fabricator completely cocked it up. so i had to have it re-done, but I painted it afterwards
carmad
awesome
did you run an intercooler?
awesome did you run an intercooler? Indeed
carmad
Nov 12, 2010 20:55:59 GMT
Awesome car !!!! nothing much to update but I made a rear bracket for the super charger Smoothed it down with the grinder and shot blasted it now painted
carmad
Nov 14, 2010 19:19:16 GMT
today's jigsaw puzzle it's a yukspeed flat pack sump kit I originally bought for my vxr engined viva But unfortuneitally it doesn't fit so I decided to use it on the van And for the life off me I couldn't get it to sit right under the van so I took the sub frame and suspension out with the dummy engine still mounted to it Turned it upside down so I could see what I was doing mocked to whole lot up and started welding to behonest if I bought this kit as a direct replacement for a manta sump I would be extreamly disapointed in it But that's not a problem for the van as I would have had to modify it any way
craig
This is quite inspiring stuff. Want to borrow my car for a few months?
