E21 Stuff - bootlid, bonnet, wheels etc
E30 Stuff - LSD, M42 engine bits, rear screen seal etc
I'm starting to have a clearout, I'll be breaking the rest of my breakers and getting rid of them over the summer and these are some of the parts already off the cars. Pickup preferred from the Colchester area, if you ask nicely I might bring them to Harlow for pick up between 8am - 4pm Mondays and Fridays. I can courier but you'll have to order it yourself.
E30 Stuff
3.91 LSD bought from Big Bavarian Beauties last year and I never fitted it. It came out of an 80k car so it's nice and tight. Will definitely need oil as I tipped some out on myself! No output flanges, £300
Black trimmed popout windows with rubbers, good condition but very dusty! £30
Black IS/sport headling £30, one small rip at the top of the B pillar
rip by the pillar
A decent M42 rocker, relatively shiny £20
M42 inlet manifold £20
M42 normal cams £25
A M42 good alternator £15
The rest of the engine is available, but the head is cracked!
Rear windscreen seal in good condition with a good condition black expander strip £15
Seatbelts, £10 front, £10 rear
A good Handbrake gaiter £3 and a good rear ashtray/bin £5
E21 Stuff
Black bootlid from a 323i, good condition except for one rust hole on the inside frame (normally much worse!) and one spot where the paints gone through on the outside. A very good base for repainting. £40
Yellow bonnet, great externally, rust holes by vents internally. £30, I have similar/better condition black bonnets
Back windshield, greenish tint? £18
M10 5 speed and linkage, from an E30 so no speedo drive £50
M20 sump for all you sump scrapers £20
Rear popouts with rubbers £35
323i speedo clocks £15
Brand new prefacelift TCAs, mis sold to me! A bargain £20 each
M20 engine mounts and rubber mounts, GR8 for M50 conversions, £25
E30 Stuff
rip by the pillar
M42 normal cams £25
E21 Stuff
