2 jetex exhaust boxes, used for about 500 miles max, round one has a small dint, nothing bad. they really do a very good job
info from site
Round silencer box [SLIM] [2.5 inch] [aluminised steel] - Dia=125mm / L=420mm - £63.56
Oval silencer box [SUPER] [2.5 inch] [aluminised steel] - H=115mm / W=185mm / L=315mm - £52.99
£70 ono
front corsa sport seats, very comfy was gunna put them in my capri but gone for light weight seats. quite easy to ft due to flat runners, have welded one extention bracket on to start mounts, can cut it off it out like. £20
mk3 2.8i rear drums, so the larger tyre, no lips on drums and shoes look gud, id replace cylinders as precaution tho. £30
also got 2 type 9 boxes, 5 speeds. one form a 4 cylinder and one from a v6, select gears with a lever £80 each.
info from site
£70 ono
