Mar 10, 2006 15:48:50 GMT
I'm thinking of putting the Rocco on 13's, but I'm guessing I'll have to drop it a bit lower (already 20mm) drop.
So - how much (sensibly) should I drop by?......and will 13's fit over the discs at the front?
Ideally want to go for 7 x 13's... but not ATS Cups!
(I might be tempted to build some banded steels....!)
Mar 10, 2006 16:03:26 GMT
i don't think you'll have a problem putting 13's on,iirc some pov spec sciroccos had them,you'll have more problems getting 7's under the arches especialy on the back as rocco's are notoriously tight for rim width.
Philj
Mar 10, 2006 16:30:55 GMT
You'll need spacers for the classics to clear the brakes, only reason I know that is that roccos have the same brakes as a g40.
Personally 13s are too small for a rocco. You'd need to slam the thing on the floor, ie a good 80-100mm to pull it off.
I reckon some nice 14x8s and 9s would do the job nicely.
Invest in some coilovers I say. ;D
thevert
Mini builder
Mar 10, 2006 19:10:39 GMT
What he said!
