fomoco
If u don't go sideways atleats once a week u will feel depressed!!
Mar 10, 2006 11:11:51 GMT
hi guys ned some help sorted ou the jeting on me zetec build. I'm running a weber dft, from early xr2s, on me 1800 but shes not getting enough fueling!!!! i wanna up the jets sizes to suit the 1800 but not sure what to go to!!
thevert
Mini builder
Mar 10, 2006 11:37:35 GMT
Size of Webber is it?
Mar 10, 2006 11:55:30 GMT
Yes you say early XR2, but which (MK1 'kent' or MK2 'CVH'), plus some XR2's actually had a 'Ford Copy' of the WEBER.
fomoco
Mar 10, 2006 15:14:39 GMT
the carb is a weber 32/34 dft, they were fitted to early mk2 xr2s, aswell as some mk3 xr3s.
pre 86 i think not sure on that tho.
Mar 10, 2006 16:04:18 GMT
... the only injury I sustained was a bumped head when I let the seatbelt of without realizing the car was upside down and that's not really the car's fault.
mayby it would be worth re making your inlet to run a single WEBER 40 DCOE would fuel it well without costing a fortune to run i bet you could pick up a single one for a good price off ebay
Hi just checking you say its not getting enough fuelling is that at idle, part throttle or full throttle. Got some info from here www.norrismotorsport.co.uk/nacvhcarburetors.htmlNow its basically saying the 34/34dmtr is better than the dft and for the dmtr for to be useable upto 140bhp the venturis need machining to 28mm so I would guess that they are around 26mm at the minute so the dft will probably have one smaller than that. Is the DFT a vacuum secondary. I am not too familar with the 1800 zetec. But I know there were two power outputs available 118bhp and 130bhp (I think) not sure what the differences are I was told a long time ago it was an ecu difference and then more recently I was told it was a camshaft difference. If you are looking on getting more power than a standard zetec I would consider binning your current carb rather than spending money on jetting it. If you want to stick with a downdraft a DGAS should be able to fuel to 140bhp without problem and you might find that the jetting is fairly close as it stands. I wouldnt bother with a single 40dcoe as they don't give any power gains over a 38DGAS and it will be more of an on sorting a manifold out to suit a side draft. hope this helps a bit
fomoco
Mar 11, 2006 19:12:41 GMT
I'm not a fan of the dmtr, used em lots before but the mechanical 2nd choke on the dft is much more controlable and responsive, and the jets in the dft are bigger to!!!
my zetec was originally a 105bhp but I'm running 2L cams, 4branch and the carb so its quite a bit more now, 130 is a guess!
yeah i have considered the DGAS myt need to aquire one!!!!
Mar 11, 2006 21:48:20 GMT
you looking into using bike carbs like old fireblade ones they go for penny on ebay will get alot more power from your engine
fomoco
Mar 12, 2006 21:41:07 GMT
id love to mate, but would need todo some research into the matter, as altho I'm a fan of bikes I'm not very knowledgable on em, learnin tho!!
