Anyone got any idea how to insure a van as a non commercial? i like the idea of an old urvan but I'm unsure as to weather id be able to lower it / fit new wheels and that sorta thing? insurance is usually killer for vans too any ideas you wonderfull lot ;D
mattc
It will be done one day.....
I've got a MK1 Astra Van insured with HIC and lots of mods
all the usual companies just have to tell them firmly its not used as a commercial and to class it as a car.
Dez
Club RR Member Number: 34
itll have to be done on 'classic' or 'enthusiast' insurance.
ive insured various (2x mazda b2000 pickups, a commer pb, a VW split van, a caddy pickup, and probably a few others ive forgotten) all with hic, and they didnt bat an eyelid at any of them, even pre-empting what mods some would have.
Anyone got any idea how to insure a van as a non commercial? I like the idea of an old urvan but I'm unsure as to weather id be able to lower it / fit new wheels and that sorta thing? insurance is usually killer for vans too any ideas you wonderfull lot ;D Dropping an Urvan would be easy. Wind down the torsion bars on the front and slip in some lowering blocks on the rear. Six stud hubs with a PCD of 139.7mm (5.5") means they are the same as loads of 4x4's. You'd be able to pick up some wide rims for one quite easily. 8j or wider probably won't clear a sliding side door without modifying the sliding mechanism.
Anyone got any idea how to insure a van as a non commercial? I like the idea of an old urvan but I'm unsure as to weather id be able to lower it / fit new wheels and that sorta thing? insurance is usually killer for vans too any ideas you wonderfull lot ;D Dropping an Urvan would be easy. Wind down the torsion bars on the front and slip in some lowering blocks on the rear. Six stud hubs with a PCD of 139.7mm (5.5") means they are the same as loads of 4x4's. You'd be able to pick up some wide rims for one quite easily. 8j or wider probably won't clear a sliding side door without modifying the sliding mechanism. haha I'm blaiming this urvan facination entirely on you!! it was your website and the cool motors on there that made me start looking toward japan for ideas.... as for wheels I'm thinking steels... like a 60's custom but not so much chrome..... i can get an urvan pretty cheap anyway... better give hic a call. My insurance is due soon so wonder if they would do a deal if i gave em a few policys ;D
Colonelk
Club RR Member Number: 83
Do HIC allow you to use it for commercial use as well? Just curious as I was thinking of going older when I get a works van.
