its about 45 cms long and 20 cms high IIRC, don't spin them over 12k rpm or they start putting out lots of hot air. whats it going on ?
HMMMM yeah it wont be going 12k... cheers for the measurments tho dude.... gonna have to see if that'll fit
RobinJI
If you don't know already it'll be an eaton M45. They've done a couple of different models if I remember right, with the main difference being a coating on the rotors. As people have said, it's a 1.6l 16v lump they use it on in the mini's, so something around that, or a little smaller if you want to run a bit more boost. I know they work well in old mini's and polo G40's, giving 190bhp-ish max in a polo. For working out sizing here's the efficiency graph for the eaton M45: ![](http://i4.photobucket.com/albums/y148/elajf1/ct_128483.gif) The green writing's the charger RPM, and the writing on the contours is the efficiency as a percentage. The pressure ratio up the left is basicaly, the boost pressure in BAR, but starting at one as atmospheric pressure.
bloody hell thats brilliant mate cheers ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
About this big* (click the link to see it better, image appears to have a clear background) www.capa.com.au/eaton_m45data.htm*Eatons come in both aftermarket and OEM specs though so there may be slight dimensional differences, snout length etc.
ahhh thats great... my google ability must be seriously lacking... i couldnt find anything like that
eaton have it all on their main site, i forgot about that as i used it for my m112 ! lol
it puts out 45ci pre revolution, so around 750cc ish, ive got a merc one on the imp, seems to be working jolly well indeed!
hmmmm well the motor id idealy want it on is 1043cc ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) gotta get the comp down tho... don't wanna be blowing headgaskets haha ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
you don't need to lower the CR, just make sure its well intercooled, or do what I'm doing and use water/meth injection. akes a curse word load of heat out of the charge air, and the meth effectively raises the octane level to 115 ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
not really 115, that's pure methanol!
you do have to be a bit careful with the compression ratio, I ran mine with 12.5:1 and 12psi, det ensued and pop went the gasket!
10:1 and good intercooling should see you right!
its a 50/50 mix of water and 99.99 percent pure methanol ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) mine is running 10.2:1, and running about 10 psi, if all goes well il be upping it to about 15 which i think should make for near close to 500 bhp ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
methanol is 140 octane, so maybe 115 is achieveable.
I would be careful of 500 bhp on stock rods ;-)
its the early 1uzfe with the beefy rods, quite a few guys running 6-700 bhp on stock bottom end. as long as i don't over rev it, keep the limit below 7.5k and i should be ok ![:D](//storage.proboards.com/forum/images/smiley/grin.png) but tbh, i don't know if i will up the boost 400+ bhp is gonna be fun ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
HMMMM, well atm the comp ratio is 9.5:1 (or at least it was new) so what theoretically would be ok boost for that? as a limit....
bearing in mind a standard g-lader /g40 will be running 10.4 psi...
Would it be worth me doing this if i was only running say 8psi as a starting point, with cooler.. and then work from there..
I still have to worry about the carb.. as they exactly easy engines to get turbo sealed carbs for... although a r5 carb might fit with a lil wiggle....
Last Edit: Jun 5, 2010 20:57:39 GMT by retrowagen1234
9.5 CR, on 8 psi with an intercooler and a tune would be fine IMHO if the engine is healthy
rangerbob
Mk1 VW Polo LS '78
There was a chap who fitted an Eaton to his 1 litre Squareback polo I'll try to find the link...
EMAIL: rcsimpson66@gmail.com facebook.com/Rob.Simpson.Design
realy? wicked ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) cheers mate , your ever helpfull as usual ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Last Edit: Jun 6, 2010 9:22:46 GMT by optima21
