well, it didn't start well. it took a while to start, i got halfway between one garage and the other then stopped. i turned it over again and got a 5 cylinder missfire. it had run out of petrol. it then started raining, so i had to leave it where it was (no h/brake).
one trip to the petol station and suprise suprise it worked.
cause it had been outside in the rain for 10 minutes it'd gone a bit more rusty.
n/s/f chassie (good side)
o/s front leaf mount
n/s/r arch (twist your head)
n/s/r leaf shackle plate
(i was very suprised this didn't disintergrate like the o/s bit did (now repaired))
the o/s sills also made out of filler but my batterys had started to go flat.
anyway, i swapped the rear callipeers around, made new pipes that fit, bleed, and put the rear half of the cable on.
modded the h/brake lever;
to
and i put some fibre glass on various small drill holes and wired the blower up. and i ordered some celly thinners.
slowly slowly....................
to
