guy
I was just wondering, what other mods i would need to do in order to fit an "kent cams A2" camshaft to a standard 1300 xflow? I know that i need the carb, bigger valve head and a four branch manifold, but what else do i need??
Thanks in advance for any help given!!!
Guy
Mk1 Escort slowly rusting into nothing! But safely stored in a dry garage. Mk2 Golf, Low n' Loud
том
"If in doubt, flat out!"
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Recurved distributor is always good with a lairy cam. high output coil, decent plugs and leads also good.
Last Edit: Mar 5, 2006 11:19:09 GMT by akku
what type of cam is an A2. If its a fairly peaky cam you will probably need to uprate your valve springs. If its mild road, standards springs should be okay but proably worth changing if they are original anyway. Head off a GT would be a good bet if you can find one. These made 77bhp IIRC with a weber carb and tubular manifold.
Any reason for modding the 1300 and not putting a 1600 in. If you are declaring it on insurance then the prices for a 1.6 and 1.3 will be pretty similar.
A2 is quite mild so you don't need to do anything to it at all. It's an old Cosworth grind with long duration so I might be inclined to go for the BCF2 which is a higher lift but less duration, so you'll get more torque out of the engine.
The big question: WHAT'S IT GOING IN?!!!
guy
its for my mk1 escort. as i am only 18 i cant get classic insurance so i cant really change the engine to anything bigger. Thanks for the help guys!!
Cam?SeventyNine
@lathamescortmk2
ah cool, I'm also a nipper with a crossflow powered escort i could get classic insurance when i was 17 with my mk2? and a 1300? try footman james mate, was £850 a year for me.
slater
Club RR Member Number: 78
Cam?slater
@slater
Club Retro Rides Member 78
You want to mod the engine but have it look standard?? Thats the way i did it (naughty) I just fitted a GT carb and exahust and declared those but also did a 90thou overbore, ported 1600gt head, Kent 234 cam etc. Used to fly, made for a very good engine!
I've got a very big expensive 4-into-1 exhaust manifold going for £40 if any of you guys are interested. See the for sale/wanted section.
