Feb 24, 2006 11:59:51 GMT
Hi J ;D Been searching everywhere for a link you posted up to Eaton M45 Pressure maps but cant find it Have you got it handy ? I am at work and havent got it here but need it and cant find it on Eatons website. It was the full map showing Drive losses against pressure/Temperature/Revs Cheers Dom
Feb 24, 2006 12:06:01 GMT
Feb 24, 2006 12:21:02 GMT
Cheers for that, Exel sheet is good I found those ones on the Eaton site but I was sure you posted up a link to an M45 3d Map like a Turbo compressor map rather than the Graphs ? Its for a GT power Simulation we need to run ;D Cheers Dom
Feb 24, 2006 12:44:49 GMT
Roots supercharger maps generally arnt 3D as they are constant volume and fixed to engine speed, the amount of air is always known. 3D maps are only used with centrifugal compressors.
J
Feb 24, 2006 12:52:37 GMT
According to first crack at your Excel sheet The 1600 Zetec SE will make 190hp ;D EDIT: At 9psi and 1.3 pulley ratio so the charger is running at 10.5K and well within its efficient operating range ;D 226 HP ;D ;D Cheers J, very useful spreadsheet for a Looksee Cheers Dom
Last Edit: Feb 24, 2006 13:19:48 GMT by CR500Dom
Mar 15, 2006 16:20:01 GMT
Just a follow up I have found the maps I was looking for and thought I would share them on here: Might be of interest to those doing a supercharger conversion. J, perhaps we should compile a Supercharger FAQ thread, as I think between us we have most of it covered ;D What do you reckon ? Links and things ? Dos and donts etc Just a thought as it would keep all the info in one thread that could then be searched for or added as a link to a sig or something ? Cheers Dom
Mr K
Mar 15, 2006 16:56:33 GMT
J, perhaps we should compile a Supercharger FAQ thread, as I think between us we have most of it covered ;D What do you reckon ? Links and things ? Dos and donts etc Just a thought as it would keep all the info in one thread that could then be searched for or added as a link to a sig or something ? Cheers Dom sounds like a good idea, start from the basics.... what is boost, etc etc. how is your setup coming along Dom? just drew up my pulley, and have the mount design in quick jottings on the desk. Nick
Mar 15, 2006 18:30:10 GMT
J, perhaps we should compile a Supercharger FAQ thread, as I think between us we have most of it covered ;D What do you reckon ? Links and things ? Dos and donts etc Just a thought as it would keep all the info in one thread that could then be searched for or added as a link to a sig or something ? Cheers Dom sounds like a good idea, start from the basics.... what is boost, etc etc. how is your setup coming along Dom? just drew up my pulley, and have the mount design in quick jottings on the desk. Nick Boost is not your friend Mine is coming along quite nicely, Pick up the new engine this weekend Ordered the new Bell Housing, clutch and Release arm today with my 20% trade discount ;D ;D Need to make engine mounts, oil filter take off plate, Supercharger mounts, exhaust manifold flange and modify the S2000 manifold to suit Inlet manifold flange and modify charge cooler to suit Got the ECU organised Got the chargecooler and super charger Ordered the low pressure lift pumps to go in the Premier Kevlar Bag tank, got Scooby High pressure in tank pump as well, need to run new fuel return line, make a New Tank sealing plate with outlets etc. Ordered chargecooler electric pump too, need to make a swirl pot/reservoir and sort a Radiator (Scooter rad will do nicely ;D ) Picking up the Piazza tomorrow for the Axle (LSD) and front brakes ;D Still need to Turret the rear to suit So Getting there, hopefully this weekend will be spent making Engine/supercharger mountings either in Steel or in MDF as Patterns to make the real ones up here in Steel during the week with the benefit of the Fab/machine shop at work ;D Cheers Dom
Mar 15, 2006 18:34:43 GMT
Hey they are super nice dom, ive never seen them before so they must be a little difficult to get!
supercharger faq would be good i think, itll have to wait untill ive finished my dissertation. Plenty of time after that though!
J
Mar 15, 2006 18:35:52 GMT
Still gonna mount the blower on a big sounding board?
*n
Mar 15, 2006 20:29:48 GMT
Of course ;D
