bstardchild
Club RR Member Number: 71
Sun roof or weld up the holebstardchild
@bstardchild
Club Retro Rides Member 71
Feb 22, 2006 22:09:18 GMT
Just loking for opinions and or advice
The GSE has a factory fitted sunroof (Tilt and Slide)
Problems are
- it weighs a fair bit
- it wouldn't look pretty without the headlining
- it restricts headroom
- it's got 22 yr old seals (so it leaks a bit and they buzz when it's open)
- The drains terminate in the sills and thats not that clever!!!
So my options are
1. Leave it where it is and try to find a new seal - suffer the weight
2. Remove it all and weld up the hole - now this might look pretty but it would be a lot of weight removed!!!
3. Remove it all and put a glass hatch (pop up in it's place)
Please note 3 was my original prefered option but it appears the size of the hole exceeds all known aftermarket sunroofs!!!
Anyone got any comments or even any better ideas?
Feb 22, 2006 22:17:19 GMT
If this is the track car; how about making a perspex piece to fill/plug the hole.
Or i suppose you could weld the original tin inplace too if your a careful welder...
Mr K
Feb 22, 2006 22:36:55 GMT
Weld up, anything else will be hard to do and keep looking good. (except leaving as it is, but that doesnt go with the spirit of the car.
what you want is the roof from another monza, to cut and weld.
bryn
Feb 22, 2006 22:39:53 GMT
I'd go with the tinted polycarb panel rivetted in place option. Did it on a P6 when the Webasto flew off years ago, worked a treat. Either that or remove it and use a sheet of carbon fibre bonded onto the roof panel...
Feb 22, 2006 22:41:06 GMT
you could always do a high quality job like this. from to makes this on
Feb 22, 2006 22:53:58 GMT
that your old man's Rover Dave? I thought he had a P5B? I like that a LOT....
bstardchild
@bstardchild
Feb 22, 2006 22:57:10 GMT
Weld up, anything else will be hard to do and keep looking good. (except leaving as it is, but that doesnt go with the spirit of the car. what you want is the roof from another monza, to cut and weld. Yeah but all the UK ones had bloody sunroofs so it's not as easy as I'd like!!!! On the continent they didn't get them as std - cost option only Keep the suggestions coming - like the perspex idea a bit!!
Feb 22, 2006 23:35:29 GMT
Snorkel scoop on the roof?
bstardchild
@bstardchild
Feb 22, 2006 23:46:22 GMT
Snorkel scoop on the roof? That would be the 83 cm x 44 cm land rover disco snorkel then!!! I'd need a few more horses to push that through the air!! I was thinking NASCAR flip up brake assists/drivers get out of jail free hatch
bstardchild
@bstardchild
Feb 22, 2006 23:51:49 GMT
A guess a big Webasto roof isn't an option ;D It was till I saw the prices they go for on fleabay!!! Of course if some one has one surplus and isn't talking dialing code numbers let me know
What about a gun turrett like the Deathmobile in Animal House:
Philj
Perspex would be the best bet I think. Solve the weight problem as well. You could try n make some device that'll let you open the rear half of it for air...
I am planning to remove mine at somepoint to gain the extra headroom and was thinking of welding a new piece in.
bstardchild
@bstardchild
I am planning to remove mine at somepoint to gain the extra headroom and was thinking of welding a new piece in. Hmm it just sounds so simple when you say it but I'm very concerned about distortion! I also don't want a roof full of Filler!!!
Steve Kiddell (sp?) with that insane 240Z on throttle bodies that I posted a few months back, had a webasto that just didn't work with the car (it was too noisy, esp at the speeds he went, and it leaked!)
He had a carbon roof skin made up and bonded over the top, it looks like a carbon version of a 70's-tastic vinyl job.
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
bstardchild
@bstardchild
Steve Kiddell (sp?) with that insane 240Z on throttle bodies that I posted a few months back, had a webasto that just didn't work with the car (it was too noisy, esp at the speeds he went, and it leaked!) He had a carbon roof skin made up and bonded over the top, it looks like a carbon version of a 70's-tastic vinyl job. Now thats a nice idea - might be a tad outside my budget tho Hmm got me thinking about Vinyl roof now Would go well with the planned paint scheme that might get done one day!!! Kinda like this posted elsewhere recently in case anyone gets deja vue but - lose the black at the bottom of the doors (orange please) - Black bonnet - Black Spoiler tailgate - No bumpers front or rear Now a black vinyl roof would fit right in wouldn't it ;D
bstardchild
@bstardchild
Problem solved New old stock Britax Sunroof - pick it up tommorrow...... Bit more than I wanted to pay but it is big enough to replace the old sunroof which is better than any of the other ones I've measured up.......
