Apr 29, 2010 10:51:44 GMT
Gonna be fittign a type 9 into my spit. I have the option of buying an off the shelf custom shalf for £130 or use the spit/sierra shafts i have already.
anybody know what thwe going rate is have a prop made up?
matt
Stu_B
Investing in rust!
Apr 29, 2010 11:03:38 GMT
About £100+
Apr 29, 2010 11:22:16 GMT
Or more like 300+
craig
Apr 29, 2010 11:31:23 GMT
Apr 29, 2010 11:33:06 GMT
If you've got both donor shafts, it shouldn't cost much at all - it's only a cut/shut job. If it was me i'd take it to any old welder/fabricator, and have it welded while both ends are held in a lathe.
I'd only bother getting it balanced if it proved to be troublesome in use.
'83 GTM Coupe. 4A-GE Powered '00 GTM Libra Auto. Ick. '71 Detomaso Pantera. Current Resto '89 GMC Safari Tow/Kip bus '05 SAAB 9-3 Daily '71 Siva Moonbug. Not even contemplating resto yet.
Apr 29, 2010 11:34:35 GMT
Seriously? I paid £280 for a completely custom 2-piece prop with centre bearing and carrier from Bailey-Morris. I cant imagine you'd be paying more than that for a simple single piece....
Apr 29, 2010 11:44:52 GMT
I had a custom prop made for a kit car i built and some driveshafts shortened by Reco Prop. They did a fantastic job and a 2 week turnaround for about £280 including courier charges and VAT. I would highly recommend them. www.reco-prop.com/
Apr 29, 2010 12:06:20 GMT
I'd only bother getting it balanced if it proved to be troublesome in use. Please tell me you're joking?? ![:o](//storage.proboards.com/forum/images/smiley/shocked.png)
Apr 29, 2010 12:10:31 GMT
I hope that too bruce ![:o](//storage.proboards.com/forum/images/smiley/shocked.png) What I do* (for shortening/custom end etc) is chop it all up and prepare for welding (ie so there is only trueing and 1 weld to do) then pass it to my local commercial prop specialists who charge me £40 to sort it ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Best of both worlds - save on labour and know it's done right too. *Somewhere in the mayday thread is some pics of this, but I'm not sure where since the page length change broke all my bookmarks...
kevfromwales
the conrod's REALLY out the block now!
Apr 29, 2010 12:11:58 GMT
^^ bruce, why?
I agree that if your fab skills aren't fantastic, it may be well worth getting a specialist to make it, but I have seen my mate make props by cutting and sleeving 2 donor props, using nothing more than an arc and a vice, and they have held up to a 360 cube, 300bhp v8, a 305 cu in small block chevy, 150 bhp zetec - even a 3ltr essex in a nissan cabstar!!
EDIT - and the prop in my f100, which stood up to MY driving!
- kfw
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Apr 29, 2010 12:16:42 GMT
I agree with KFW myself, but it depends on your ability/knowledge. if you or no one you know is quite sure then getting a pro to do it makes sense.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
Apr 29, 2010 12:35:38 GMT
surely worth the 30-40 quid for piece of mind
a prop through the floor. at speed, is no fun
Apr 29, 2010 12:37:29 GMT
It's not the quality of my welding, or my chances of getting it true by eye that makes me get the pros do it for me.. I like to know that it isn't minutely out of true and isn't going to destroy the the U/J's, the gearbox or the axle a short way down the line. It is cheaper to get the prop done properly than it is to buy another axle ya see... and yes... a snapped prop at speed is no fun at all. I've seen a sierra flipped onto it's side by its own prop, and a MGBGT in the scrapyard that luckily had no-one in the back when it let go
Apr 29, 2010 12:57:55 GMT
I went to bailey morris cost £160 for mine from mx5 front to spit 1500 diff. with uprated UJ's.
Apr 29, 2010 12:58:02 GMT
the triumph specialist near me sells all the type9 conversion parts, including off the shelf props for £131. i think for the hassle and peice of mind, and that £131 sound reasonable, i'll go with an off the shelf one. I can then keep the original prop.
Apr 29, 2010 17:07:20 GMT
Seriously? I paid £280 for a completely custom 2-piece prop with centre bearing and carrier from Bailey-Morris. I cant imagine you'd be paying more than that for a simple single piece.... That's what reco prop wanted to charge me for a custom one..... ![::)](//storage.proboards.com/forum/images/smiley/eyesroll.png)
Apr 29, 2010 19:34:13 GMT
a cut and shut job at my local prop place was 110 quid ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
stevea
Apr 29, 2010 20:09:33 GMT
I had a custom length propshaft for my GT6 made by Dave Mac propshafts in Coventry www.davemacprops.com/dmphome.html They were very helpful and knew over the phone what flanges to use once I told them the car. IIRC it was about £100 plus delivery. Quite likely that a local Triumph parts supplier also uses them for their custom propshafts.
Apr 29, 2010 20:20:27 GMT
My mate welded up the last one i needed, he's a pro welder who builds race cars but he did it by eye, i gave him the bits and he did it in about 5 mins, turned out to be dead on for weights and trueness.
I think the guys paying lots of money are buying whole props and those of us getting them cheap are supplying all the bits ready to be joined up.
