Apr 29, 2010 16:23:20 GMT
I need some advice then guys (amour?)
The thing will only run with the choke 80-100% on... even once warm. As soon as you drop the choke below that point it cuts out & dies
Anything I can look for?
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
Apr 29, 2010 16:43:43 GMT
what condition is the plug? sounds lean, is there an airfilter in the box? adjust the idle mix jet
Fungus
Apr 29, 2010 16:52:45 GMT
^^^ what he said. Try running it on choke at high revs, then take the choke off. If it will just about run, fiddle with the mixture screw, which i believe is the small goldish one near where the airbox joins on. If not, try going all the way in with the screw, and then 1/2 a turn out. Keep going untill it will run well off choke. When i had mine, i was exactly the same, but once the carbs set up thise engine pull really well
Apr 29, 2010 17:11:50 GMT
Plugs in good clean condition, filter is in the box (I patted the crud out of it)
Ill try the full revs trick. There's no throttle cable - well its not attached at the handlebars end - does this control any of the idling?
Apr 29, 2010 18:31:19 GMT
bit of throttle jiggling usually required to get little bikes started, what colour is the plug, white black or tan?
Apr 29, 2010 18:58:40 GMT
bit of throttle jiggling usually required to get little bikes started, what colour is the plug, white black or tan? Starting's not so much an issue.... its mainly the 'keeping' it running part! (plug is tan BTW) Symptoms/behaviour are: -- It starts with no choke and a little throttle - but not at all with the choke engaged. -- Once started I quickly have to whack the choke to fully engaged to keep it from dying
Apr 29, 2010 19:12:05 GMT
okay tan plug is good, sound a bit more like the idle(second one forward of the airbox) needs setting, screw it in and try again.
Apr 29, 2010 19:13:58 GMT
okay tan plug is good, sound a bit more like the idle(second one forward of the airbox) needs setting, screw it in and try again. Its screwed all the way in
Apr 29, 2010 19:28:30 GMT
Screw it out then
Apr 29, 2010 19:31:34 GMT
Screw it out then LOL, I should have said that Ive tried it at a few differing levels already
Apr 29, 2010 19:43:22 GMT
not sure I can add much help. I had running issues with my mower engine, but it seams to have sorted a lot of the issues out all by itself! I just gave it an itallian tune up! Shouting was involved, so perhaps a few suitable expletives might help!
Fungus
Apr 29, 2010 20:13:30 GMT
Sounds really stupid, but has the choke lever got any markings on it? I just thought that is sounded the exact opposite of what usually happens
Apr 29, 2010 20:17:46 GMT
Sounds really stupid, but has the choke lever got any markings on it? I just thought that is sounded the exact opposite of what usually happens Only got a choke symbol. TBH honest i assumed that pulled all the way up was full choke and pushed down was no choke
Fungus
Apr 29, 2010 20:18:10 GMT
Also, its gonna run like curse word with that header, and lose a lot of power Perhaps it only runs on chocke because the pipes leaned it out so much :\
Fungus
Apr 29, 2010 20:20:55 GMT
Well just to be sure, whip the airbox pipe off and have a look. Mine had a carb like yours, and all the way up was no choke Worth a shot, but if not, do the full revs thing and just gradually work the screw outwards untill the engine note smooths out
Apr 29, 2010 20:32:27 GMT
I'm gonna strip the carb down tomorrow, clean it in a load of petrol. Ill check the pilot needle hasn't got any curse word in it etc. I'm pretty certain the choke is on when lever is up... the revs slow up as you pull the lever down.
valman
Apr 29, 2010 20:55:08 GMT
hmm don't know about you, but that looks like an expansion chamber to me (the bit you cut off)
Apr 29, 2010 21:01:28 GMT
hmm don't know about you, but that looks like an expansion chamber to me (the bit you cut off) Yeh, it definitely does. The engine is a 4-stroke though so not too reliant on the pipe (well, nowhere near as much as a 2-stroke). Plus I hacked it off mainly because it was shagged (little holes in the side etc) It was running the same when I was riding it around at work - pre-stripdown & hacking. Its running no worse with the pipe off. I might just give it away TBH, the last thing I need is another project when I'm trying to move house!
Fungus
Apr 29, 2010 21:17:37 GMT
Seriously? If you actually are going to give it away, let me know
Fungus
Apr 29, 2010 21:18:37 GMT
Or a least take if off your hands for a while if you want it back Oh yeah, its deffo a four stroke, the big nuts on the head are for adjusting the valves
