Feb 20, 2006 22:58:53 GMT
ri.
work i need to do.
1 - fit the other front spring. 1a - possibly grind the front arches. 2 - get the front calipeers plumbed in properly. 2a - bleed. 3 - weld scabby bits underbody (1x left). 4 - weld scabby bits inside body (1x left). 5 - wire up heater. 6 - find the correct h/brake cable. 7 - sand blast all the scabbed electrics. 8 - track up steering. 9 - buy proper sized m/c. 9a - bleed all the bleeding brakes, again. 10 - make bodywork better. sand/grind 11 - learn how to respray. 11a - respray! 12 - weld in a battery tray. 13 - wire in battery 14 - wire in c/l 15 - wire in e/l 16 - wire in alarm 17 - make sure all bolts are tight, splitpined and safe! 18 - buy/fit worm cog atb lsd diff.
I'm sure theres more than that.
Feb 20, 2006 23:01:34 GMT
oh yeah, ive got to refit all the interior. that can be 16a.
Feb 20, 2006 23:04:05 GMT
......what are you waiting for then ;D
Feb 20, 2006 23:04:13 GMT
strutbrace can be 19.
Feb 20, 2006 23:08:27 GMT
sparkplugs can be 17a. hacking up everything for the stereo can be 16a. makeing holes for the side repeaters can be 7a.
What is it, a Capri? Expect to find a lot more rust when you start cutting the old stuff out. Allow at least 6 months I reckon, maybe a year.
If it be an early Capri that has been out of commission for a long time then check those door pillars
What number are the rocket packs and home made nitrous Dave?
You got that Cossie motor running yet?
Feb 21, 2006 20:33:26 GMT
motor runs, sound sweet, then sometimes dies due to a lack of backpressure (hopefully!) unless you rev it. the n2o can be 20. :cool: its 86, and ive welded about 3/5 bits. theere 2 other bits but there a wing off job each side, so they can go f*ck themselves.
Feb 21, 2006 20:50:23 GMT
no 'zorsts on it yet? you also might be fooling the lamba sensor. All mannerof poor running problems can be fixed by fitting up proper exhausts. I hava slight blow in the Olds, doesn't blow all the time for some odd reason, anyway, when it blows the car idles bad. When its quiet, the car idles well. I think its a split at the bottom of one downpipe.
It will all be worth it when its done.
Feb 21, 2006 22:22:50 GMT
manifolds and down pipes. carefully dropping all the CO directly under the drivers seat.
exhaust is 9b. i can make something out of the masses of scrap. hopefully.
Feb 21, 2006 23:21:17 GMT
If you're like Racer86, it should take you about 2 days. If you're like me, hmmm... about 3 years? ;D Good luck with it buddy!
thevert
Mini builder
Feb 21, 2006 23:56:49 GMT
i thought i was going to take 1 month, taken so far..........8, it just depends how perfect you want it i suppose.
