Bellhousing is available from Shawspeed for £230 to fit a type 9 Box.
The bellhousing bolt pattern is different as its a Yamaha engine
The other alternative was to strip the standard gearbox down to just its bellhousing and clutch release slave, cutt off all the unused lugs and remachine to take the type 9....... but for £230 I couldnt be ed ;D ;D
AS for timescale, I am hoping to get it ready to go in, in the next 2-3 weeks, thats engine gearbox and clutch sorted and together, with Megasquirt built and ready to run the standard inlet arrangement. then I have engine mounts to fabricate, S2000 exhaust manifold to modify ;D
I will run it as it comes out initially, then fit the chargecooler and supercharger once I know everything is working ok.
I can hopefully do most of the fabrication work for that here at work ;D ;D
But any other Ideas gratefully recieved as always ;D
Cheers
Dom
Cheers
Dom
