Apr 22, 2010 16:19:08 GMT
Thought this would probably be of interest to some of the RR fraternity. www.locostbuilders.co.uk/viewthread.php?tid=134615Its a hydraulic ram that fits underneath the spring on a coilover setup and therefore allows the ride height to be adjusted from inside the car while maintaining a constant spring rate, adjustable damping etc. I'm not sure whether they're infinitely adjustable or designed to run either at full or empty. Far from cheap at £750 for a pair of rams (I believe), plus the pump, hoses and coilovers, but interesting and compact none the less. EDIT: just found a price of £1700 for a whole kit, coilovers not included.
Last Edit: Apr 22, 2010 16:20:17 GMT by Adam
Seth
Apr 22, 2010 16:30:50 GMT
Wow! Very cool but out of my reach! I guess they must only provide up to 1 1/2" or so movement? I'll stick to C spanners!
Apr 22, 2010 16:32:34 GMT
Extra unsprung weight as well, might make a difference on a light car like a 7
Apr 22, 2010 16:52:35 GMT
There must be loads of pneumatic stuff in RS that can lift a car. Bet you could bodge something like this up on the cheap that uses nothing more than cigarette lighter gas and some teflon hose
Apr 22, 2010 19:01:23 GMT
Wow! Very cool but out of my reach! I guess they must only provide up to 1 1/2" or so movement? I'll stick to C spanners! Yeh they're more for just giving that extra bit of ride height where needed on performance cars than the trick stuff found in proper hydro cars. Still, if you had a bit of money and wanted a suspension setup that handled admirably on the track and could sit on its bump stops on the show field then they'd be perfect. That extra inch or two of ride height would make all the difference. I bet if they were to catch on then prices could fall dramatically. As I said, they're far from cheap but a very interesting solution none the less!
Apr 22, 2010 19:03:19 GMT
On the suspension setup it's shown on you get almost twice as much wheel travel as spring travel, so a 1.5" lift at the spring would equate to 3" at the wheel.
Seth
Apr 22, 2010 19:11:20 GMT
On the suspension setup it's shown on you get almost twice as much wheel travel as spring travel, so a 1.5" lift at the spring would equate to 3" at the wheel. Ah yes, fair point. I was just thinking of Mcpherson struts where it would be pretty much 1:1 While it might be designed for performance applications as you say, it would be a darn sight easier to install as an improved quick ride height adjustment to any coil over converted car compared to starting all over again with some sort of airbag strut set up. WOuld allow you to run softer springs in a slammed car as you could drive at a slightly raised position and still dump it for showing off ;D Hotwire, you Datsun will need this technology
Tim
Apr 22, 2010 19:56:40 GMT
Thats very clever. Something i've imagined in my minds eye before :-)
Is that the sort of thing that supercars run?
RobinJI
Apr 22, 2010 20:08:29 GMT
Exactly the kind of thing I've been trying to work out how to make for the front of my mini, but I haven't got anywhere near that kind of cash. I just wan't it so I can run it at a decent height for track use, and still get over speed bumps.
Tim
Apr 22, 2010 20:16:20 GMT
Seth uses a slightly lower tech idea to similar effect :-)
Tomarse
Low Standards
Apr 23, 2010 11:35:17 GMT
That's a very nice little set up there.
v8ian
Apr 23, 2010 12:07:00 GMT
anular clutch realse bearings spring to mind [no pun intended] Is it me, or is the bleed nipple at the bottom in the pics????OOps
Last Edit: Apr 23, 2010 12:09:08 GMT by v8ian
