Apr 11, 2010 18:31:44 GMT
I need to put a new exhaust on Gladys. The system has a 2 pipe input one pipe output silencer, then straight pipe with secondary silencer. Getting the main silencer made in stainless is going to be expensive and it doesn't need replacing. So what would you do. A = Bodge it with scaffold pipe B = New mild steel system from main silencer back cost €70 + postage C = Stainless from rear of main silencer cost £180 D = Stainless full system cost a whopping £270 Paul
Rocco
Merc Mafia
Apr 11, 2010 18:41:20 GMT
D , Go full stainless, do it once and do it properly ! job done
Apr 11, 2010 18:46:56 GMT
have to admit its a car you love and no doubt intend to keep.. full stainless FTW I know soon as I have the dollar I'm off to reading to get one built for the humber
Apr 11, 2010 18:52:38 GMT
like that james bond song.... stainless are forever.
Brian Damaged
West Midlands
Club RR Member Number: 33
Mild or Stainless?Brian Damaged
@damaged
Club Retro Rides Member 33
Apr 11, 2010 18:57:12 GMT
It's only got two cylinders. Silencers are for pussies.
;D
Apr 11, 2010 19:07:41 GMT
Stainless is always best in the longrun.
CIH
Apr 11, 2010 19:20:05 GMT
stainless if it's a keeper, mild if it's a shitter
Apr 11, 2010 20:21:27 GMT
B - cheapest option that's not a huge bodge, put stainless on in 3 years time (when you have finished uni and can afford it...)
Apr 11, 2010 20:44:13 GMT
What the man above said - B (or a, but use proper exhaust pipe not scaffold)
Apr 11, 2010 20:52:57 GMT
B wouldn't be a bodge at all really as the main silencer is good and silencing well. As are the down pipes. Thats stock parts imported from a speicialist in the netherlands. I like the idea of putting stainless on her but think it might be overkill. Got a message from the previous owner telling me that the brackets and fixings are stainless.
Apr 11, 2010 21:01:55 GMT
It's only got two cylinders. Silencers are for pussies. ;D DAF with no rear silencer. I think its a wee bit louder. Specially as you sit at high revs a lot with the vario.
