Well, here is your chance to buy a sequential LPG system complete with the tank. This is a Zavoli Alisei N Matrix system. Why am I selling it? At the moment I do not seem to have a use for it, considering my new car is a 6 pot and this is made for a 4 cylinder car.
What does it comes with? Almost everything. To give you an idea, the following will be included:
Vapouriser
Matrix injectors (complete with 2.2 Nozzles)
ECU
Wiring loom (including Bosch plug adaptors for Bosch injector plugs)
MAP sensor
Switch/Level indicator
67L Toroidal tank
Coolant pipe for vaporiser
What will you need? You will need the following some of which you would need anyway:
Multivalve/Sender unit for Toroidal tank (around £50 for a new item)
Pipework (I use (and prefer) Copper pipes for this, but you can now get flexible pipe which still meets the LPGA Criteria).
P Clips (very cheap anyway)
Vacuum Hose and other Hose assortments (T Piece x2 for Coolant tap offs).
The system worked very well before it was removed with the vapouriser delivering a good consistant pressure and it not suffering from icing maladies etc.
I want £350 but I am open to offers. Pics will go up soon.
Vapouriser
ECU
MAP sensor
67L Toroidal tank
