Feb 14, 2006 21:24:03 GMT
Has anyone come across one of these short glass fuses before? I could do with a 4 amp one for the Rambler... the US spares place I use couldn't help me. I wondered if anyone had come across them used on another car?
... the only injury I sustained was a bumped head when I let the seatbelt of without realizing the car was upside down and that's not really the car's fault.
Feb 14, 2006 21:40:05 GMT
2001 HONDA CT110 (NOT RCV)
Feb 14, 2006 21:43:55 GMT
cant you go get a modern fusebox from a newer car and rewire it in?
I'm planning this, although, i remember seeing in classic ford somewhere that sold a standard escort fusebox but with modern fuses? anyone got any ideas?
Yes! Appear to be same size as what WAS on my 1981 Yamaha XJ550. I say 'was' because about 8 year ago I found I could no longer get them and the fuse box was braking up/corroding so I replaced the whole unit with a modern blade fuse box set up. You might like to try a motorcycle dealer but I think you will come to a 'dead end' as I did.
Never seen fuses like that on a yank car. I had a Rambler similar age to yours and I have an Oldsmobile.
I suspect someone used that to replace the fusible links somewhere in the car and it was what they had handy
Last Edit: Feb 15, 2006 9:30:18 GMT by akku
Never seen fuses like that on a yank car. I had a Rambler similar age to yours and I have an Oldsmobile. I suspect someone used that to replace the fusible links somewhere in the car and it was what they had handy It's in the standard fusebox, so I have to assume it's original... It's a bit of a strange set-up, there is this short fuse, one standard length glass fuse and 3 slightly shorter ones... the holders have little tags on the spring clips that the fuses fit between, so longer ones don't really fit properly, and they nearly touch... someone had fitted a 13 amp plug fuse in one of them... (and the fuse in the photo has had a piece of wire soldered across it...
Feb 15, 2006 11:35:51 GMT
том
"If in doubt, flat out!"
Feb 15, 2006 11:43:08 GMT
they're continental fuses, i got one that size in the sled, and the rest about twice the length.
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Feb 15, 2006 12:13:16 GMT
Maplins (best bet, shop online) or RS Components (trade only).
Peugeot 307sw - Suzuki SV650S - MX5.
Feb 15, 2006 17:59:00 GMT
As wagoneer says maplins or RS. I have some 20mm fuses like that but no 15`s. You should be able to order those from CEF (city electrical factors) as well thats where I normally get mine from.
Feb 15, 2006 20:40:53 GMT
That forum looks good... I've signed up. Thanks for the sugestions, looks like Maplins might be worth a try...
