All prices collected from Cumbria CA7 district, can post smaller items at cost. Pair of Mk1 rear spring shackles £16 Inlet manifolds Black powder coated x flow rocker cover £12 Land rover folding seat £20 Land rover hinges £5 XR3i petrol filler cap with carbon fibre insert £10 Escort hazard switch and plug with 9” tails the left hand one in this picture £12: Set of 7/16th locking wheel nuts for escort £15 X flow alternator £15 Raydot rear fog lamps x 2 still got boxes and packing but used as extra brake lights for a couple of weeks £10 14” spare wheel cover £8 Modified to remove all sold items
interested in ram, would you post?
theres more to life than mpg & to much power is just enough.
Happy topost justa quw estion of finding a reasonable courier. Would need to check the weight as 30kg limit on parcel2 go and parcel monkey, I think the oil would need to be drained outof it too. I'll have a look and get back atb Mike
Interested in the crossflow manifold on the left hand side of the picture. How much including postage?
Cheeers
Dean
Dean just had a rake through the box it should be in and it isn't there I'll have a better look later on but I'm guessing it has ben sold or swapped - by sod's law the other 2 are there of course! atb Mike
Interested in the engines but i`m miles away. Don`t spose you ever travel south?
Interested in the engines but i`m miles away. Don`t spose you ever travel south? ... notwith 4 engines inthe back Priced to go as they are - always worth travelling for a pile od f stuff rather than just one part. Where are you located ? atb mike
engine stand and lifting ram gone, left hand manifold ingroup of 3 can't be found!
Apr 12, 2010 21:48:43 GMT
Judging by the exhaust manifolds they look like RWD engines but could you just confirm they are all defo RWD? Cheers.
street
6.2 ft/lbs of talk
Apr 12, 2010 22:07:45 GMT
What model Weber carb is it please?
Apr 12, 2010 22:15:35 GMT
Hi Yes all RWD engines out of MK 2 escorts the carb is a 32DFM from a 1600 x flow weighs about 2kg similar to the one fitted on 1300 GT engine I think, hth Mike
Apr 13, 2010 21:37:38 GMT
Could do with the engines but trying to justify the 650mile 12hr round trip & £100 fuel!
Apr 13, 2010 23:43:37 GMT
Looks like engines have gone - just sorting out arrangements for collection tomorrow
Edited to add: 4 engines now gone, head gasket set gone, 32 DFM carb gone
Apr 17, 2010 14:03:02 GMT
+30 pistons for 1600 x flow now sold
