thevert
Mini builder
Feb 11, 2006 19:09:14 GMT
Feb 11, 2006 20:44:55 GMT
Looks like she's going to be a mean machine...
Feb 11, 2006 21:47:24 GMT
cool!
what is going to be the final spec?
thevert
Mini builder
Feb 11, 2006 22:28:18 GMT
still not decided how much power i want from the engine but so far its 1380cc running on a weber carb, LCB manifold. Shell has a carbanfibre front and bonet with brace bars fitted to the sub frame. Rear seat has been cut down with pockets removed. rear cage fitted, fabficating the front half soo, front and read arches modifyed for clearance suspension wise its useing blue cones with spax adjustables, adjustable camber bottem arms fixed rear 1.5 degre rear camber brackets all poly bushed. Metro turbo vented disks with 4pot calipers, braided lines. um, miglia arches and when i can afford it, 13x7 (or 8) ultralights with A048R's think thats it..................
Feb 11, 2006 22:30:14 GMT
pretty much just standard then it sounds great!
Feb 12, 2006 13:29:45 GMT
ooo ooo ooooooooo ;D coming on nicely, keep up the good work
thevert
Mini builder
Feb 25, 2006 21:55:38 GMT
Last Edit: Feb 25, 2006 22:12:49 GMT by thevert
Feb 25, 2006 23:06:45 GMT
Looking good fella Liking the Black roof... been thinking about doing that meself ;D
thevert
Mini builder
Feb 25, 2006 23:12:44 GMT
Feb 26, 2006 19:17:52 GMT
cool. Minimal Mini look? They be biggazzed cuttouts in the front wings!
thevert
Mini builder
Feb 26, 2006 19:48:08 GMT
Yup, goin for the bumperless look, wings are cut for 13's, looks quite silly with 12's and no arches!
Feb 26, 2006 21:21:29 GMT
looking very good so far - do you intend keeping the rubber mounts on the front subframe?
I kept mine for about a week after putting my 1380 in, the pull you get from the engine soon destroys the mounts - I welded in strengthening plates to the floor and front (as well as seem welding the subframe) before fitting solid mounts.
It made so much difference......
You might want to think about upgrading to stronger cross-pins as well (and poly bushes if you haven't alread).
Did you just weld plates over the rear light cluster holes?
85%DarrenW
@darrenw
Club Retro Rides Member 74
Feb 26, 2006 22:19:19 GMT
Looking great!
85%rustingdeathtrap
@GUEST
Feb 26, 2006 22:23:16 GMT
This might be a stupid question but what are you doing for rear lights, (this is a road car right?) I remember a mini in street machine a few years back that had the rear lights in the back window. I think they look the nuts with the back end smoothed off like that though
thevert
Mini builder
I would like to put them behind the rear screen, MOT man don't like that tho as the lights has to represent the with of the car. I'v bought landrover lights to go on, not decided where yet tho! I'v poly bushed the whole thing, might have to see how i get on with the mounts and replace stuff as it breaks
