Mar 31, 2010 21:05:37 GMT
I have a 1300gt ford engine for sale. it got the 711m casting on the block. it all complete with twin choke webber dizzy alternator fly wheel and clutch ect. it came form a kit car as the owner was fitting a 1700 in it. I was told it is a good engine. £150 ono located in hertfordshire call 07949 248537
Last Edit: Mar 31, 2010 21:06:31 GMT by crumble
kee
Mar 31, 2010 21:52:42 GMT
711m is a 1600 is it not?
Mar 31, 2010 22:18:46 GMT
No 711 just means crossflow post `70 i think. The bit at the end of the engine number indicates cc. BA =1600 AA =1300
Mar 31, 2010 22:22:49 GMT
711m is a 1600 is it not? taken from ... www.burtonpower.com1970 saw the big change to the thicker-walled 711M block with square mains caps, large diameter followers, wider cam lobes and modified crank seal. Also, the head was now completely flat. There are two main capacities of 711M, determined by block height – the 1600 is 7/16” taller and you can see the difference between it and the 1300 by the space between the water pump and head. Also, the 1300 has 711M 6015 AA cast in the side whereas the 1600 ends in BA. The engine was also fitted to 1.3 and 1.6 Mk1 Fiestas in the 80’s with a 771M casting. These feature no side engine mounts plus a shortened water pump and timing chain/crank area.big al
highly tuned for poor economy and increased pollution
the casting number is 711m6015aa so that should be a 1300 then.
Jun 26, 2010 11:21:05 GMT
hey is this still for sale ?
