Hi guys/gals. I have been toying with white wall tyres for the bus for some time. I am not sure what to go for, narrow , or wide bands, or maybe even red bands. Thanking you all in advance. Here are a few photos. Firstly, an example of what looks really good, a photo Sammm took down under. Keeping in mind it is not the bus, but the combo looks spot on to me. My favourite. Narrow white band Red band in the background. Side view of the bus for you to play with.
Last Edit: Mar 20, 2010 7:33:28 GMT by grizz
If you fit any the front will need to be lower :-) They highlight arch gaps imo.
Matt
Just a quickie: Not sure which is best.
If you fit any the front will need to be lower :-) They highlight arch gaps imo. Matt Good observation Matt, maybe not such a good idea then, but lets see what comes up on here if someone does do a photoshop. The front cannot come down any more, it is down by about 2 blades and would be pig to drive with more out. The rear was dropped by 6 blades.
Last Edit: Mar 20, 2010 8:38:08 GMT by grizz
...but lets see what comes up on here if someone does do a photoshop. Er...
Just a quickie: Not sure which is best. Morning Simon, Hope all is good with you guys. Thanks for that, the white narrow band beats the red in my eye. Cheekily I will ask, can you do a wide white like in the Holden photo above ?
VIP
Given your final paint scheme, I'd say redbands win.
Mar 20, 2010 10:16:47 GMT
Given your final paint scheme, I'd say redbands win. Good thinking there VIP.
Chrisâ„¢
This is clearly filler material.
Mar 20, 2010 12:34:38 GMT
1989 Volvo 340 1986 Suzuki SJ413 2000 BMW 318ti 2006 Lexus IS250
Mar 20, 2010 17:31:46 GMT
Interestingly, Nicola also said none of the above as the bus paint scheme and graphics will be quite busy, so maybe not in the end.
But as it stands, I do like the white rings Rmad did earlier.
Seth
Mar 20, 2010 21:25:09 GMT
Interestingly, Nicola also said none of the above as the bus paint scheme and graphics will be quite busy, so maybe not in the end. But as it stands, I do like the white rings Rmad did earlier. Agreement form me! Looks great with the whitebands in Simons 'shop but with the paint they seem to become a bit superfluous.
