том
"If in doubt, flat out!"
Right, haveing a bit of trouble with the electrics...
The indicators, the wipers, fan, basically all the swithes on the dash bar the lights don't seem to be working. when i pull them out, wipers for instance, the AMP light on the dash glows bright red, and the needle on the rev clock drops back down, along with the fuel needle. this is the same with all the swithes, like instead of doing there job, they're causing a huge power drain Any ideas?
Cheers
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Nathan
Club RR Member Number: 1
electrical problem...Nathan
@bgtmidget7476
Club Retro Rides Member 1
Have you put a multimeter on any of the cntact to see if your getting power
том
not yet, i'm still tracing wires, they've been buggered about with quite alot in the last 37 years
have you been under the dash and looked at the wiring there? also check the fusebox. check earth terminations. in my experience electrics on a lot of cars gets messed about with by people who only think they know what they're doing. i hate dodgy wiring.
том
checked the wiring, looks fine, no burning or anything that i could see, fuses seem fine, i'll check the earths. then drop it into the garage
That sounds like a fuse gone. I had it happen to me before, its had something to do with the way the car was grounded, but it turned out to be a fuse?
thevert
Mini builder
I'm just starting from scratch on my loom making it myself, the guy that rebuilt it in 1999 fecked it up
electrical problem...rustingdeathtrap
@GUEST
sounds like a bad earth to me. Check the fuse board and all the conections for corrosion. Although, if your not 100% certain what your looking for i'd say it was worth paying an auto electrician a few quid to sort it out. It'll save a lot of grief later on.
onlyrwd
'78 Cavalier 4 door / '78 Manta Berlinetta
Bad earth or a dead short which kills everything in a one-er...
Mick Gradually trying to own one of everything
