Mar 13, 2010 18:48:58 GMT
My mate has locked this keys in the boot Anyone know how to get in the boot of a 1999 Mondeo salon??? only way of folding the rear seats down is a leaver in the boot Anyone know Also how easy is it to get a new key from ford??? Thanks
markbognor
Club RR Member Number: 56
Mar 13, 2010 18:54:58 GMT
Now I have a way you could solve that.
Mar 13, 2010 18:56:44 GMT
send a small child into the boot through the "ski hatch" (rear seat armrest) or use a torch/coat hanger to find them through the hole instead. And ford are a pita for getting keys, especially if it was your last one and you don't have the red master key
Mar 13, 2010 18:58:43 GMT
Take out the bench seat. Undo the bolts at the bottom of the back rests and the rear seat should come loose. Then you might be able to reach in or send a small child/land mammel in to retrive ones keys.
At least thats how i got in the boot of my sierra sapphire.
1987 Opel manta GT 2.0 16v 1976 Opel manta s project 1985 Opel Rekord E 2.2i 1992 Vauxhall Carlton 2.3TD 1989 Mercury Grand Marquis 2005 Landrover discovery 3
Mar 13, 2010 19:05:03 GMT
Now I have a way you could solve that. Which is??? There is no ski hatch
markbognor
Mar 13, 2010 19:05:50 GMT
Mar 13, 2010 19:11:41 GMT
Is that a jonny in your boot next to your keys?.
Mar 13, 2010 19:20:17 GMT
Mar 13, 2010 19:25:29 GMT
I'm guessin theres not an interior boot release on mondeos then? If i remember rightly my orion and sierra saph did and they were older than '99
1984 Subaru GLF Hatch 1983 Skoda 120LE Super estelle 1977 Subaru DL Wagon 1978 Datsun 120Y Coupe 1995 Skoda favorit estate
Mar 13, 2010 20:51:47 GMT
Cant you just drill the lock out?
bortaf
Mar 13, 2010 20:58:32 GMT
Is the rest of the car open then, can you not sit inside lock and unlock the C/L? sorry don't know Mondeos that well? i take it the boot is key only entry not push to open ?
R.I.P photobucket
chevazon
1939 Chevrolet 2 door coupe, `67 `Zon estate, `87 Ragtop Cavalier, 4 x 800 Drifters,(!) 1500 Drifter
Mar 13, 2010 21:06:37 GMT
Something similar happened to me with a C180 Merc. Battery was disconnected so couldn`t open the boot (different lock and didn`t have a key) or the doors with central locking. Passenger door (with a conventional lock) was up against a wall. Had to use 2 jacks to move car away from wall then squeeze into car (I`m a big fellow) rive out parcel shelf and speakers then with aid of torch and coat hanger lift battery lead onto terminal. Only took about 4 hours ! Good luck fella.
Mar 13, 2010 23:00:27 GMT
Not any help, but I've got the exact tool for that, but your a bloody long way-away.
If its a standard Ford type key could you try a different Ford key they all seem to open each other.
Matt
Spray a bit of water over the bootlid. Shoulda rusted through in 5 mins Is there not a way you could poke something between the back of the seat and the rear window to hook the seat latch? Although.... if its got foldable rear seats... that'd make it a hatchback no? Nothing parcel shelf related? This is of course, assuming you have access to the interior. Was wondering if the drilled lid would get posted too, haha.
If its a standard Ford type key could you try a different Ford key they all seem to open each other. Not since the 70's!, I know a Ford key will lock any Ford but they won't unlock them. That's a good point about the pacel shelf, If it has one just cut a hole throu it and replace it from a scrapyard.
Mar 14, 2010 10:02:37 GMT
how did the car lock after you had shut the keys in the boot?? if it just locked.. and not dead locked? you should be able to pump the top of the door open.(use screw driver to start it then little wooded wedges to keep it open..) then you should be able the get a length of wire down in side the car to the inner door handle to open it, the central locking should do the rest?!! if that don't work.. rip the number plate of.. drill a hole were the plate would sit, and get a coat hang in there to pull the keys out!! bit of duck tape over the hole and refit number plate job done!! worked for 5 years as recovery driver, 9 times out of 10 could get in a "lock out".. bit more tricky if it had been deadlocked! and if non of that works.. find some one with a the same type key.. and try and "jiggle"the lock!! ford locks are the worst for ,wair in the barrel! we had a key that seemed to open most fords of the same age!!
Last Edit: Mar 14, 2010 10:06:41 GMT by petetong
wez
Ratty Fords FTW
Mar 14, 2010 15:09:50 GMT
if its anything like my old mondog 1996 saloon, the boot could only be opened with the key. Even if the cars central locking was unlocked, the key still had to be put into the boot lock and turned (below rear light), then the boot would just 'pop' open without the use of any handles. No boot pull either. I'd try jiggle the lock with a simmilar looking key, take a grinder to behind the armrest or smash a back light through. You can rive the lock out with a flat screwdriver, but then theres bodywork/paint repair to contend with. Have a pic of said vehicle on its final voyage:
Last Edit: Mar 14, 2010 15:13:04 GMT by wez
Maximum signature image height = 80 pixels
Mar 14, 2010 16:35:30 GMT
As I said, no other better ideas than removing the rear light cluster (with a hammer). Cheap and easy.
Mar 14, 2010 16:42:50 GMT
If you have access to the interior, and your central locking in working correctly, then the boot should open by pressing the boot lock inwards.
Same set up on my '99 Mondeo....
Last Edit: Mar 14, 2010 16:44:06 GMT by Takeshi
1992 Sierra XR4x4
