Mr K
is it neccisary to have a rear fog light on a car? (1976 reliant kitten - didnt have one fitted) Also, i don't think it has a reverseing light so was doing to fit one like: (sorry, stole it from another thread) how do you wire these up? switch on the dash? Cheers Nick
if your gearbox has the switch built in for reversing lamp, you could use that to switch a relay for your rear mounted spot if not then it would have to be a dash mount switch, not sure on mot's veiw of seperate switches for reverse lamps tho
2006 Audi A3 2003 Fusion 2 looking for a project....
thevert
Mini builder
You don't need a reversing light, when i was reading about fog lights it never said any car was exempt but i know i would rather have one anyway (gets well foggy up here in Aberdeen) I am going to mount it behind the rear screen, wired up to a toggle switch on the dash.
fog lamp should be ok off normal dash switch as long as you have a bright lamp near it to tell you there on! mot requirement i believe, but may have to be wired so it only comes on with sidelights or headlights, this would also help to stop you leaving them on
fog light for MOT is needed after '78 I think. reversing spot lamps may be a grey area with the police
thevert
Mini builder
if your gearbox has the switch built in for reversing lamp, you could use that to switch a relay for your rear mounted spot if not then it would have to be a dash mount switch, not sure on mot's veiw of seperate switches for reverse lamps tho You can have any amount of 'work' lamps(can class it as a work lamp). You don't evan need [glow=red,2,300]ANY[/glow] lights! Aslong as you tell the MOT man its only used in daylight hours and it is put on your V5.
