Jan 29, 2006 20:07:21 GMT
ok, my little baby popped a water pipe on firday afternoon after only just getting her from a garage.
It got water all over the engine, and it blew the alternotor (cant spell that word) shorted the regulator were it got wet.
So have replace everythink, just gone to start her, and she is shorting somethink out some were, as when you start she goes pop with white smoke, down by the alt?
Any ideas?
Jan 29, 2006 20:21:00 GMT
is it a new alternator? i got water all down mine once, took it off dried it out then put it back on. worked without a problem.
Jan 29, 2006 20:24:35 GMT
its a new alt and still smoking its shorting somethink but its working out what
Jan 29, 2006 20:26:27 GMT
there may be some water still trapped in the wiring harness thats causing the prob?
Jan 29, 2006 20:27:24 GMT
how you find out, sorry I'm learning at the moment
Jan 29, 2006 20:39:17 GMT
possible help; is one of the bolts into the alternator too long? had this on a bmw , the bolt that held the earth strap on was too long and touched the "live" workings inside the alternator. lots of smoke but instantly when battery was connected not just when trying to start it. I hope that is help rather than confusion
Jan 29, 2006 20:51:39 GMT
Could be that a wire got trapped when the alternator was replaced, and is shorting out... I had it happen to me on the Astra, though in that case it flattened the battery...
... the only injury I sustained was a bumped head when I let the seatbelt of without realizing the car was upside down and that's not really the car's fault.
onlyrwd
'78 Cavalier 4 door / '78 Manta Berlinetta
Jan 29, 2006 20:56:48 GMT
Make sure on the main positive feed it has a small insualting washer or stepped washer going inside the alternator body. If thats ok make sure non of the positive wiring or connections are touching the altenator earthed body.
Last thought, does it have a metal cover over the back of it, if so make sure the bolts aren't too long and touch it...
Mick Gradually trying to own one of everything
Jan 29, 2006 20:59:02 GMT
cheers guy have sorted it now, but now its a worrying case waiting to see if the fan kicks in, or weather the car will over heat
As my temp gauge don't work even thought replaced everythink you can think of. it only works when it wants to
onlyrwd
Jan 29, 2006 21:39:50 GMT
What was da problem??
Jan 29, 2006 21:42:46 GMT
no the main prob was that she blew a water pipe (rad one) for some reason need to sort out why
Jan 29, 2006 21:52:05 GMT
Hmm, sounds like you may have some kind of fault.
HTH RR
onlyrwd
Jan 29, 2006 21:58:30 GMT
If the electric fan doesnt come on often then it can start to sieze up, being winter it probably wont be on much. If when it does come on it is slow to start and is stiff then the current draw would be too much and blow the fuse.... other option is maybe the fan switch on the rad is dead. To test it, pull the wires off and join them with a paper clip with the ign on, see if the fan works...this should point to the problem....
том
"If in doubt, flat out!"
Jan 29, 2006 22:02:12 GMT
i've found if you rag the curse word out of it, the fan'll come on what ever the season,
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Jan 29, 2006 22:10:51 GMT
ermm well the boyfreind has taken her, out but not back yet, so no doubt ragging her. dead when he gets back
