Model: daihatsu mira 850cc
Year: 1993
Mileage: 80,000
Tax: 4-5 months
MOT: 4-5 months
Price: £200
Additional Information:
for sale is my daihatsu mira 850cc 5 door....
basically i've been using it as a cheap runabout, for which it has been perfect for! its not the most clean well kept automobile, but gets from A to B everytime as cheaply as you could hope for! with a bit of love i'm sure it could be made into something quite cool and quirky, but I couldnt cope with a fwd car any longer so it has to go!
the bad points about the car I suppose.... roughly beaten out front drivers wing, blowing exhaust (although I think its just a loose joint at bottom of downpipe, as the system doesn't look too old), wheels are wrong pcd! (running bigger 13" fiesta steels for economy! pcd is slightly different,ya can moan about the rights and wrongs etc. but theres not ever been an issue with them! tyres are pretty good too mind!) at some point needs new driveshaft on pass. side. CV boot has torn and it clicks when accelerating whilst turning right. been like it since me and the owner before has had the car and again, not been an issue! just don't do burnouts on full lock and it'll be fine! apparently daihatsu move ones fit and aren't all that expensive. also there is a slight knock when going over bumps, not sure whether thats a bush gone or whether its just cos the cars a cheaply made tin can on wheels! ok another bad/good point depending on how you look at it.... the cars an import (2001) so insurance can be annoying to get hold of dependant on which company you are with, it does mean you get something a bit different from the norm tho!
overall the car is quite tatty, but does the job of moving around perfectly fine! its a tax and tested car that starts every morning and returns 50+ mpg! cant argue too much with that! oh and its got a brand new set of pads on 'un too!
pictures too follow, as I will need to take some tomorrow!
Year: 1993
Mileage: 80,000
Tax: 4-5 months
MOT: 4-5 months
Price: £200
