please can someone help me? my screen on my laptop seems to of moved? if you have it just showing the desktop,it has moved over 2" to the right and about almost a centimetre down.leaving a black border round?
thanks in advance paul
SPOTS MUSH!
Could be a few things tbh... I would be checking software (display preferences) for problems first but I've also seen similar effects from a panel that is starting to lose sync and is about to die Is it properly centred during boot (welcome screen/splash screen) ie problem only happens when the desktop appears?
cheers its weird,been doing it for some time now.i just turned it off to see what it does on start up and its fine now?but it will do it again.. from what i can remember it comes up with -lenovo,on the screen as it should but when it changes to the windows start up screen its off to the right? thanks
SPOTS MUSH!
Sounds like it might have messed it's drivers up (I'm assuming windows XP) try reloading them via control panel and see what happens.
thanks again,is it easy to do?I'm not the best at computers but i do know how to get to the control pannel..lol,just a bit of guidence from there would be great.. cheers
SPOTS MUSH!
You might have to wait for a "windows guy" to notice this thread for a better answer, but as far as I remember from my (limited and painful) experiences with XP it should be control panel>hardware>pick your display from the list (might even have a yellow triangle warning on it if it knows it's faulty) then click advanced tab and reload driver. Maybe
rysz
Control Panel > System > Hardware > Device Manager > Find the display adapter and then right click on it and 'Re-load Driver' IIRC - I am on Windows 7 now and I know that is a little different Almost there SOC! Rysz.
rysz
