Jan 20, 2006 13:03:58 GMT
Recently some members and I in a couple of local car clubs have been curious as to what PCD / offset the wheels of their vehicles are (and if they will interchange with certain other models by same manufacturer) if say they wished to change style. I am asking because last year I was informed buy a couple of fellow members and a moderator of RetroRides that in the RetroRides Wheel PCD chart there are some discrepancies The vehicles wheel PCD / and if compatability info that I/we would like to know about are: British LeylandMarina MGB / MGB GT Also will Marina and MGB interchange wheels? Rootes GroupSunbeam Rapier Series 3A ( 1961 ) Hillman Hunter/Minx, Humber Sceptre, Singer Vogue (The 'Arrow' model code name) ( 1966 - 1978 ) Also will Rapier and Hunter interchange wheels? OpelManta AManta B & CAnd can Manta 'A' interchange wheels with Manta B&C ToyotaI know FWD Corolla is PCD: 4X100 but what about Rwd ones of 1960's and 1970's Toyota Corolla And finally what is PCD for: Toyota Celica RA28 (1976- 78) Many thanks for any help you can provide.
Jan 20, 2006 13:10:38 GMT
I know the MGB has a 114.3 PCD, they share that with quite a few British sports cars, but I believe the Marina is different.
Last Edit: Jan 20, 2006 13:11:15 GMT by reallyloud
Mike
East Midlands
Jan 20, 2006 13:10:50 GMT
Marina and MGB are both 3.75" x 4, i think..
i could be wrong! ;D
Last Edit: Jan 20, 2006 13:12:36 GMT by Mike
Jan 20, 2006 13:13:47 GMT
Thanks guys this is what I need, knew it would be best to ask here due to such diversity of vehicles on Forum. Keep it rollin'
antdat
Jan 20, 2006 13:15:40 GMT
i'm sure the toyota is 114.3 same as the mgb and most datsun/nissan
Jan 20, 2006 13:18:11 GMT
Not sure on all of them, and I haven't checked the chart here (I have a PCD chart from 20+ yr old copy of Street Machine which I remember most of), but I thought later Rootes are same as Ford?
Most 4-stud RWD Toyota are 114.3, so Corolla and Celica should be the same, but little 1000 (and maybe early Corolla?) is possibly smaller? Sure I remember someone in the TEC saying that some of the wider wheels foul and aren't necessarily a straight swap.
I (well, Nick did!) found this on my Laurel C32 - it won't take the wheels from a C210 as it has ginormous backing plates behind the front discs which foul the slightly chunkier rim of the older wheel.
So, it might be wise to trial fit a wheel before buying!
Then there's nuts/studs of course - I know Skyline alloys will fit on the Starlet, but they use a shank-type nut, and Toyota has different thread, grrrrrr.
And finally there's centre bore - 5-stud Datsun and Toyota wheels are same PCD, and I had a nice set of CROWN alloys lined up for my 300C, but Cedrics have a huge bit (technical term) coming out from the hub.
Jan 20, 2006 13:22:22 GMT
gen 1. celica pcd is 114,3 x 4
ps. will post piccies of my retro-geisha asap
Last Edit: Jan 20, 2006 13:27:18 GMT by redbaron
1976 Toyota Celica s/t 2000 liftback (japanese copycat-art stretched to the limit)
bstardchild
Club RR Member Number: 71
Jan 20, 2006 13:27:13 GMT
Manta A '68 to '72 GT rims are ET 25 & 4 x 100 untill '73 when they used the "mag" style rims on the GT which are ET37.
Don't know if anything changed after that?
Jan 20, 2006 13:32:15 GMT
Thanks guys, I jotting all this down. Spottedlaurel: Yes I did wounder about Centre bore Red Baron: So Celica RA28 is same PCD as MGB ...well, well Bastardchild: didn't know a car so old would be using 4X100 (4X100 is used a lot today!)
Jan 20, 2006 13:32:25 GMT
Marina = 3.75" (except some vans which are 4.5") Hunter = 4.25" (pretty sure the Rapiers are the same) MGB = 4.5" Manta = 100mm (earlier examples may be 4") RWD Toyota = 4.5"
ps. 3.75" = 95.25mm, 4.25" = 108mm, 4.5" = 114.3mm.
Common fitments? 3.75 = Marina, Herald, Spitfite, Toledo, Dolomite, MGF, Maestro, Montego. 4.25" = Ford, Porsche 924/similar age Audis, Hunter/Rapier, Sunbeam. 4.5" = RWD Toyota & Datsun, MGB, Triumph 2000/2500/Stag, A60 (Cambridge/Oxford).
Jan 20, 2006 13:34:42 GMT
Marina and MGB are both 3.75" x 4, i think.. i could be wrong! ;D You are!
Jan 20, 2006 13:47:44 GMT
I was hoping rmad would 'burst in'! ;D Thankyou, Thankyou, Thankyou, Thankyou, rmad YOU ARE BRILLIANT! Thats all sorted then! I would however like to thank ALL fellow members for your help and contribution Didn't realise the British sports cars and Rwd Toyota were same! AND would have thought Marina and MGB would have been same ... but not ...so thats messed us up with regards to sticking some MGB Rostyles on a Mates Ital ;D ...really did learn something today Spotted laurel also raised a good point about wheel nuts Redbaron: Oh yes I think we need pictures
bstardchild
Jan 20, 2006 14:00:50 GMT
Bastardchild: didn't know a car so old would be using 4X100 (4X100 is used a lot today!) Well you made me question my own memory now and I know there was a change in offset in 73 but maybe that was when it changed to 4 x 100 as well and prior to that it could have been 4 x 4" I'm trying to find some info that will coroborate my original post but the guy I need to speak to is in the USA with his Manta A ;-)
Jan 20, 2006 14:31:06 GMT
Jan 20, 2006 14:46:41 GMT
in the PCD list we have here, is there a facility for notes to be added? Like spottedlaurel mentioned about the backing plates on a C32, might stop people making incorrect purchases as i know a lot of folk check here first and then buy on that basis.
too many variables to have extra columns like "size of backing plate" and "length of bolts needed" etc but just a comments field for anything people spot....?
Mike
East Midlands
Jan 20, 2006 14:46:42 GMT
Marina and MGB are both 3.75" x 4, i think.. i could be wrong! ;D You are! Damn! *Gets coat...*
Jan 20, 2006 14:50:35 GMT
Ah yes but mike would be right with regard to some Marina Vans which are 4.5
Rob
You know, for kids!
Jan 20, 2006 18:15:33 GMT
Marina = 3.75" (except some vans which are 4.5") Hunter = 4.25" (pretty sure the Rapiers are the same) MGB = 4.5" Manta = 100mm (earlier examples may be 4") RWD Toyota = 4.5" ps. 3.75" = 95.25mm, 4.25" = 108mm, 4.5" = 114.3mm. Common fitments? 3.75 = Marina, Herald, Spitfite, Toledo, Dolomite, MGF, Maestro, Montego. 4.25" = Ford, Porsche 924/similar age Audis, Hunter/Rapier, Sunbeam. 4.5" = RWD Toyota & Datsun, MGB, Triumph 2000/2500/Stag, A60 (Cambridge/Oxford). so thats what you were doing while i was drinking thunderbird and talking 'boobies' !!!
Jan 20, 2006 19:07:31 GMT
All the mantas are 100mm.
Jan 20, 2006 20:18:29 GMT
Maestro Vans are 4.5" as well ( I used to run Maestro van rims on the back of AE86 for autotestin ;D)
I believe mantas are 4x100 as they are Opel`s and therefore use the metric system and chevettes/kadettes also 4x100. That could be a load of bo11ox though
