Jan 24, 2010 22:33:57 GMT
Evening, Been having some steering issues with my Volvo 240 lately. It developed the ability to steer by itself. But only if you wanted to get pulled into the oncoming traffic. I don't remember hitting anything to knock the tracking out but I went and got it checked and it was 'loads out, mate'. So the local tyre place sorted that for me and it nolonger pulls me across the road. It doesn't seem to self centre either. I have to battle the wheel back to centre from either left or right, and sharp changes in direction are very hard work. I have to use enough force that it made me wander whether it was maybe the PAS. I don't reckon it is though.. I'm reckoning an alignment issue and will be taking it back to the place that did it to see if they can check their work. What I want to know is what it's likely to be so I can at least sound like I know what I'm going on about. Or is this likely to be something else? Cheers Ben
Seth
Jan 24, 2010 22:39:19 GMT
Didn't you change the rims on it recently? Could the offset be all wrong as that could cause tramline-ing and random pulling.
Jan 24, 2010 22:41:48 GMT
one of the wheels arent buckled are they?
1984 gtm coupe 1979 mini clubman estate pickup 1990 mini racing green 1996 mini sprite 1992 maestro 500 van 1995 fiat cinquecento
Jan 24, 2010 22:45:26 GMT
Seth- Yep, but to Volvo wheels that were offered on the Volvo 240 (albeit a higher spec one) Rooster- it's something to check, I hadn't considered that. I've got a couple steels in the garage that I'll try tomorrow, then if that doesn't sort it, I'll go to the tyre place after that. Thanks guys
purplevanman
Way too orangey for crows
Jan 24, 2010 22:58:21 GMT
jack her up and give the wheels a shake and pull. Hands top and bottom give a wobble, hands side to side and give a wobble, this should show up bearing play and steering play. Bottom balljoint is a bit harder, i use a lever and jam it twixt the hub carrier and the bottom arm and try to move the joint that way. Odd size tyres?
I had an issue last week with a wandering truck, turned out the steering drop arm was loose !!
Welder, fabricator, general resto work
Jan 24, 2010 23:12:49 GMT
Cheers Alan, I'll have a check of all of those things. to clarify, the tyre place did resolve the pulling to the right issue, but it isn't returning to centre. I do have a feeling that the wheels are playing a part. All the symptoms have shown near immediately after fitting. Whether they are the cause or just highlighting a problem better than the old wheels I'm not sure...
Jan 24, 2010 23:27:51 GMT
Its usually castor angle that stops them self centering,so i guess worn balljoints could affect that. Sometimes helps if the tyre pressures are upped a little and the fronts are adjusted to toe out slightly.
johnrh
Jan 25, 2010 18:23:02 GMT
I think you need a full laser alignment check, not just tracking, but first jack it up and make sure nothing is sticking.
As said above, castor angle provides the most of the self-centre effect, so you need to know that is within spec. Tracking won't measure or affect that.
As you say, the Virgo alloys are correct for a 240 so should work fine. Who fitted the previous, deep dish wheels? If fitted before you got the car, it's possible that they created instability under braking due to the different offset creating positive scrub radius. If something was modified/adjusted to get rid of this, that could now be creating a problem with Volvo wheels fitted.
Good luck with it
John
93fxdl
Enter your message here...
Jan 25, 2010 21:15:31 GMT
just a suggestion, had problems with swmbo,s sedona, hard to steer, not self centering was caused by the ujs in the steering column siezing ttfn glenn
namless
Club RR Member Number: 26
Steering issuesnamless
@namless
Club Retro Rides Member 26
ben what's the mileage the cars done?
Jan 26, 2010 12:19:13 GMT
I'm coming up to a quarter of a million miles.. God knows how much of everything is original. Certainly not all of it..
Thanks for the continued suggestions, guys. John, it was Si (black8driver) that originally put the big wheels on. I'll ask him at the weekend. Whatever happens, I need to jack it up and see what it feels like with the front end in the air.. look for worn/seized parts, then look at getting it aligned properly.
Edit: not as many miles as I remembered.. Thinking about it, it's 'only' 220,000 miles.
Last Edit: Jan 26, 2010 12:20:49 GMT by ben711200
namless
@namless
Jan 26, 2010 13:43:59 GMT
ben you probably realise its either the rack or the blimin UJ joints from the rack to the column. that's because they seem to last about 200,000 then tends to get a mind of its own and having lowered Volvo's at -5" drop doesn't really help
