paul4be
'86 Capri Laser, Frontera 4x4
Jan 15, 2006 21:10:29 GMT
I want to get rid of the engine driven cooling fan on the Volvo when I fit the new rad and replace with an electric fan.
I don't want the fan controlled from a dash switch, I want it temp controlled. What's the best (and cheap!!) way to do this without spending loads on a Kenlowe/ Pacet thermostatic control??
Ta.
Jan 15, 2006 21:17:17 GMT
deemon tweeks, lil thing costs about £50 goes hard to explain il look for the website www.turbobricks.com/mods.php?content=art0008good description and pictures of how to convert a 740 to E-fan, same princibles with the 240
Last Edit: Jan 15, 2006 21:23:38 GMT by samyboy
Rob
You know, for kids!
Jan 15, 2006 22:05:12 GMT
Last Edit: Jan 15, 2006 22:06:13 GMT by Rob
paul4be
Jan 15, 2006 23:29:04 GMT
The fan itself is easy, not bothered by that. The Kenlowe etc controllers ataround £50 are more than I want to spend on this. Looked at the stuff on Ebay, but wondered if there was a cheap scrapyard solution???
Jan 15, 2006 23:31:40 GMT
look in the scrap yard for something with an inline electronic thermostat thingy is my guess
or look in the yards for a FWD volvo or late 900 range they should have all the E-fans and sensors u need
Last Edit: Jan 15, 2006 23:32:40 GMT by samyboy
Mr K
Jan 15, 2006 23:35:34 GMT
deemon tweeks, lil thing costs about £50 goes hard to explain il look for the website www.turbobricks.com/mods.php?content=art0008good description and pictures of how to convert a 740 to E-fan, same princibles with the 240 don't buy it from demon tweeks....... i can guarentee you can find it alot cheaper else where.
Jan 15, 2006 23:41:34 GMT
get yourself a temp switch from the scrappy i usually use a montego one there set at 110 degre c bit of copper pipe the inside dia of the top hose drill a hole in the copper pipe solder the switch in Then run a live to the fan citron bx i use then run a neg to the swich then to the fan and there ya go when the engine gets hot the fan cuts in automaticly hope this helps andy
paul4be
Thanks all
