Jan 15, 2006 21:06:50 GMT
hey, i've been thinking.
you see these dubs and bugs...with turbo, etc etc engines...there are some out there running 200bhp + aren't there?
what gearboxes do they use?
Jan 15, 2006 21:11:41 GMT
it varies. Most are standard but heavily uprated bug or bus boxes. Companies like Rancho build heavily uprated boxes to the same dimensions are beetle boxes. Drag cars sometimes use mendeola's which are pretty much bullet proof ... but they are enormous in size. Another common one can be porsche 901 or 915 boxes. As you can see, there are quite a few different routes people go down ...
Jan 15, 2006 21:12:30 GMT
hmm...and i doubt any of them bolt onto an RX-8 engine....
Jan 15, 2006 21:28:46 GMT
surely an adaptor plate can be made though. There are many RX-8's with big power already though, why not look to the 'box that they typically use? Any reason why you were looking for a vw box?
Jan 15, 2006 21:32:49 GMT
VW box, because they are rear engined and the power goes to the rear wheels...
was trying to think of any 200bhp+ rear engined cars....other than a 911...
mason
Jan 15, 2006 22:33:41 GMT
you can get adaptors for the rx7 motor to fit tothe vw trans, try a search on volkszone,pretty sure there has been some stuff up recently
mason
i've just remembered that someone has already put a wankel in an estelle...i need to get hold of him.
Jan 17, 2006 14:04:17 GMT
The Renault UN1 box is good for 250bhp but can get expensive if you want to put more through it. But they are getting a bit thin on the ground now.
If you expect over 250 then (I understand) There is an Audi/VAG box that can be used.
Jan 17, 2006 15:35:00 GMT
AA, what kind of gearbox does a Renault 21/Espace turbo diesel have. I know it’s a transaxle, is it a UN1?
I ask cos I have one of these in my cellar.
Jan 17, 2006 17:10:57 GMT
MrB, I don't think it is. I'll try to check my info this evening but IIRC it's from the R25 V6 (& V6 Turbo), R21 Turbo Alpines and something else (V6 Espace maybe), as well as Alpine GTAs and Lotus Esprits.
Jan 18, 2006 21:37:40 GMT
OK, I checked with a friend who confirmed 'R21 Turbo, Alpine, 25 Turbo, 25 GTX 2.2 and Renault Master used the UN1. Renault Master final drive is too low for road car use though..
The other models of 25 used the NG3, which looks similar, but much weaker and completely different.' Cheers
slater
Club RR Member Number: 78
gearbox longshot.slater
@slater
Club Retro Rides Member 78
Jan 18, 2006 22:07:45 GMT
I did a little bit of reserch when i was looking at putting one in a mini pickup, basicly the 21 turbo box is the one to have, best ratios apparently. Used alot in GT40 replicas too.
Jan 18, 2006 22:30:22 GMT
where d'you get these g/boxes from...scrappers?
mason
Jan 18, 2006 22:42:24 GMT
Renault Master used the UN1. Renault Master final drive is too low for road car use though.. ahh but what does the rotary rev to?
Jan 18, 2006 22:43:07 GMT
8 or 9k.... ?
You can make a mid mounted setup with a FWD gearbox but you cant rear mount the engine as it would be running in reverse unless you flip the box/diff or run a Honda engine
Jan 19, 2006 11:01:55 GMT
You can make a mid mounted setup with a FWD gearbox but you cant rear mount the engine as it would be running in reverse unless you flip the box/diff or run a Honda engine The Alpine GTA uses the UN1 box with (I think) the diff flipped. Some non transverse engined FWD cars already have the box ahead of the engine.
