street
6.2 ft/lbs of talk
Jan 15, 2006 16:42:06 GMT
HOW much are trumpets for webers/dellortos?!?! Ive had a go at making my own, so thought i'd post them up ;D I didnt know how long to make them....... i heard that long trumpets give you more torque where as short ones are better for low end power, so i made them super long, so that i can cut them down and alter them later ;D They're angled so that they clear the bulkhead on the escort. I managed to get a bit of a flare on the ends, but its about as much as you can do with only a hammer and a vice
том
"If in doubt, flat out!"
Jan 15, 2006 16:44:05 GMT
what did they start life as?
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
street
6.2 ft/lbs of talk
Jan 15, 2006 16:46:15 GMT
what did they start life as? Umm, a length of steel pipe and some 5mm steel plate for the bases Ghetto trumpets ;D
том
Jan 15, 2006 16:54:43 GMT
*puts hands and fingers in a strange pose* "word"
Jan 15, 2006 16:54:47 GMT
Nice one! Yea, length is better for torque...looks like a nice setup anyway, might be worth 'rouding' the bottom with a bit of sandpaper so it flows better?
street
6.2 ft/lbs of talk
Jan 15, 2006 17:07:19 GMT
Nice one! Yea, length is better for torque...looks like a nice setup anyway, might be worth 'rouding' the bottom with a bit of sandpaper so it flows better? Yeha they do need a bit of fettling. Because the tube was lopped off at an angle to get the rise, the angled end obviously then had a bigger diameter So i used 38mm pipe, and the angled end became 40mm ish once cut, which i then beat out with a hammer and flared it from an oval to a circle again, so i ended up with a 40mm flare at the base (does that make sense?) The only trouble there is, the trumpets are effectively flared at each end to 40mm, where as the rest is 38mm I don't know what thats going to do for performance
Jan 15, 2006 17:10:35 GMT
Make it better! Ram air! ;D (maybe) lol
Jan 15, 2006 17:17:36 GMT
I think you'll need more of a flair on them for it to be effective, but yours look cooooooool that long!
Did eBay fail you for stuff like that?
I doubt it will affect performance noticeably being 38mm. Don't forget the chokes only go up to 36mm for 40's so you're still bigger than that. The flair is the most important part as I understand it and the most expensive ones are the ones where the flair is rolled back on itself. Try making some as long divergent cones. If you pie-cut some 50mm tube (or bigger!) you can get it to taper from 50mm down to 40mm. To put the flair in you can bash a steel ball into the end. You can get big 60mm solid steel balls off eBay for about £5 and they make perfect flairs in tube.
Last Edit: Jan 15, 2006 17:23:27 GMT by Deleted
Jan 15, 2006 17:33:36 GMT
Nice job. I'm not sure what the're like for performance but they sure as hell sound nice ;D Mine were £50 ish from ebay
Kris
Jan 15, 2006 17:36:52 GMT
There is a good section on trumpet design in David Vizard's "Tuning the A-Series engine".
slater
Club RR Member Number: 78
trumpets for 40's....slater
@slater
Club Retro Rides Member 78
Jan 15, 2006 18:17:21 GMT
How much clearance you got between carb and bulkhead? you'd be better off having them staight and 1/4" long than with that angle. Thats going to upset the carbs a bit i would say.
people say longer is better because the optimum length is usaly way longer than you can realisticaly make them but you loose quite alot when you try and make tha gasses turn corners expecialy when they are sharp like yours.
street
6.2 ft/lbs of talk
Jan 15, 2006 22:39:19 GMT
Thanks for the advise fellas ;D Yeah i guess the angle isnt ideal, but the bulkhead is rather close to get a decent length on there. I suppose i'll just run them and see what happens! I may have a go at doing a decent flare on the mk2's Ministrone your engine bay is as clean as the outside! ;D
