ok the names geoff I'm from south london, mitcham to be exact ( so any locals say hello)
have been trying to get rid of my 200 and ended up with this little gem, and as ive wanted an 86 for a long time I was rather chuffed
want to do a few bits too it, but its been a hoot so far. I can only hope there are a few meets that we all do? and I really do hope this is a lively comunity(just like the old ford one I used to be in)
spec and pics
Ae86 shell seem welded 1985 steel wide arches at rear 4" and 2" front (standard) all hole welded in for strength
Coolkits body kit in silver widened rear bumper to match the arches,skirts trimmed to fit.
Wheels are 15x8 front and rears
Also have x2 15x10" steel banded wheels for track use fitted with yokohamas 205 50 15
8 degree steering lock kit (gives you more angle of steer)
Driftworks adj tie rods
Whiteline adj panard rod
Cusco camber adj topmounts
Coilover adj fronts teinko shocks all round
Strut brace
Driftworks drivers seat 2 months old. standard passenger.
Hydro h'brake and drifters handbrake
Guages are oil press, water temp and volts
Nardi steering wheel
6 point roll cage (J unknown make) shaped to car and braced to pillars of car
TRD quickshift standard 5 speed box (thrust bearing bit noisy)
4 paddle clutch (no slipping)
Digital dash (rare old type)
Electric mirrors and windows, heated rear window
Electric cooling fan (on switch)
Air filter with polished alloy intake
Trophi blue intake and cam cover. Polish s/s spark plug cover(new)
Jasma s/s tubular downpipe in to decatpipe into s/s system 3" tailpipe
Engine earthing kit
Brake servo strentghening/cooling kit
Trd rad cap
ill update changes once things start to happen in a project thread or something
spec and pics
Strut brace
Engine earthing kit
Trd rad cap
