Jan 11, 2006 19:30:49 GMT
Without wanting to experiance the wrath of all the mini owners out there, How easy is it to put a late 1.1L Metro engine and box into a mini? when I say how hard what I mean is how cheap? The reason I'm thinking about this is I've got to start rebuilding my fiancee's mini pretty soon and I really don't want to throw money at rebuilding a leaky old A series engine and box when I might be able to use the engine and box from her metro. OR Debate....
slater
Club RR Member Number: 78
Stupid question! or is it?slater
@slater
Club Retro Rides Member 78
Jan 11, 2006 19:40:17 GMT
Put it this way, if your going to go to the trouble of putting something non-aseries in there you should find some thing a little better than a cruddy 1.1 k-series!! Id rebuild the a-series, 1275 lump with minor tuning would woop a k-series and much less hassle. If you want a-series help/parts then you know where to find me
Jan 11, 2006 19:45:13 GMT
Stick a 1.6 in there while you're at it ;D
Mr K
Jan 11, 2006 19:47:02 GMT
i beleive a rover V8 will bolt upto a marina (?) gearbox, and with a clubfoot front end there is enough room for it too.
Jan 11, 2006 19:55:12 GMT
a rover V8 won't bolt to a Marina box, which is RWD anyway so no use for a mini. You're thinking of the princess box, which it won't bolt up to either, but which is at least FWD. Apart from that, you are right.
том
"If in doubt, flat out!"
Jan 11, 2006 19:56:49 GMT
they drop metro turbo engines in mini's all the time
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Jan 11, 2006 19:57:54 GMT
i beleive a rover V8 will bolt upto a marina (?) gearbox, and with a clubfoot front end there is enough room for it too. a rover V8 won't bolt to a Marina box, which is RWD anyway so no use for a mini. You're thinking of the princess box, which it won't bolt up to either, but which is at least FWD. Apart from that, you are right. PWN3D!
Jan 11, 2006 20:03:45 GMT
Basicly I really hate A series engines with their stupid gearboxes especialy when the price of gearbox rebuild kits are silly money, for what you get. I'm not building it for speed (good job) but more for ease of maintenance and I'm quite liking the 1.1 engine in her metro as it's conventional and straight forward. Christ I sound like my dad! Quick sell me a Vtec ;D
Jan 11, 2006 20:04:48 GMT
Where's that lad who was stuffing a 1300 16v from a dead Micra into a Mini - that sounded a proper bo idea - updates?
SidewaysGTM
Spending my time at the Race track, Pub or in an Engine
Jan 11, 2006 20:06:35 GMT
a rover V8 won't bolt to a Marina box, which is RWD anyway so no use for a mini. You're thinking of the princess box, which it won't bolt up to either, but which is at least FWD. Apart from that, you are right. oh it will bolt up to a princess box theres a v8 mini done like this by a chap called sprag i think made a custom adaptor plate etc etc anyways, if your not wanting to spend much money stick with the a series, as sticking in that k wont be easy, easier with a honda or vauxhall as there are kits to do it but cost ££££££ and will take some work all depends how far you want to go WEST
Live life sideways, Honda Powered GTM Coupe, you better belive it GTM Coupe VTEC Constant progression and acceleration 67' Triumph Vitesse 2ltr [finally decided what to do with it, at the planning stage] 92' Mini nearly std [SOLD and Missed] GTM ownersclub forum
Jan 11, 2006 20:25:37 GMT
a rover V8 won't bolt to a Marina box, which is RWD anyway so no use for a mini. You're thinking of the princess box, which it won't bolt up to either, but which is at least FWD. Apart from that, you are right. oh it will bolt up to a princess box theres a v8 mini done like this by a chap called sprag i think made a custom adaptor plate etc etc WEST He's called spag, and you're right, he did graft a rover engine to a princess box, after machining the bottom of the block away and making an adaptor plate to go where the sump was on the rover engine. Not what I would call a 'bolt on' job... Mega impressive all the same! www.spagweb.com/v8mini/
Jan 11, 2006 20:27:32 GMT
Where's that lad who was stuffing a 1300 16v from a dead Micra into a Mini - that sounded a proper bo idea - updates? Wasnt that V8mike? If that proj gets off the ground it will be fugging legendary, sounds like the perfect mini upgrade to me.
Jan 11, 2006 20:41:43 GMT
Hey nick this pic makes me crack a smile everytime I see it Theres something stupidly funny about tormented cats (in a completly none harming RSPCA friendly way of course) Aparently smarties tubes on the legs is a hoot but I wouldn't know anything about that of course.
Jan 11, 2006 20:58:52 GMT
It's certainly not easy. You'd either have to fabricate your own front sub frame or spend around 1500 notes on one of the kits. The k-series subframe available actually widens the track so mods are required to the rear also. There is a subframe available that allows you to fit a 1600 vaux engine under a std length round nose (this is the route i'm planning for my mini - one day ) </afaik> I guess the easiest/cheapest option is to just drop in another a series, although i s'pose they're not as readily available these days. check out www.16vminiclub.com/forums/ for ideas.
Mr K
Jan 11, 2006 21:04:51 GMT
oh it will bolt up to a princess box theres a v8 mini done like this by a chap called sprag i think made a custom adaptor plate etc etc WEST He's called spag, and you're right, he did graft a rover engine to a princess box, after machining the bottom of the block away and making an adaptor plate to go where the sump was on the rover engine. Not what I would call a 'bolt on' job... Mega impressive all the same! www.spagweb.com/v8mini/AH HA! see.... i said it could be done! lol.
SidewaysGTM
Jan 11, 2006 21:35:25 GMT
well any engine can be made to fit with a bit of engineering and money, i have a Honda in place of a A series in my GTM now that is a tight fit, but its worth it WEST
том
thats a nice looking mini
Last Edit: Jan 12, 2006 0:36:51 GMT by том
Davenger
It's only metal
Club RR Member Number: 140
Stupid question! or is it?Davenger
@dminifreak
Club Retro Rides Member 140
Yeah, been a fan of this one for ages Love the E30 lights
I'm sorry i don't like doris the fwd v8 mini, too barry for me, i much prefer the more evil sleeper created by Viku Perala, of finland, when he was messing about trial fitting his rover v8 from his speedboat! in his clubby that can be found here..... www.geocities.com/jharkola/Viku2.htmlhe also owns a metro turboed mini and a minor if anyone else is interested, just click link to his home page from v8 mini page
2006 Audi A3 2003 Fusion 2 looking for a project....
