Is it possible to fit 4x100 wheels onto something that's supposed to be 4x101? If they 'go on', can I be certain they won't 'come off' again at high speed. I'm sure this question has been asked a thousand times, but I was twatting about at the back of the classroom at the time and wasn't paying attention
Depends on the wheels and the method of attachment, I think...
*n
Just thinking about the wheel options for the Minor.... have plenty of 4x100 spare
I reckon 1mm isn't going to make much difference. It'll stretch each stud or nut by 0.25mm which isn't much. I probably wouldn't do it if the wheel uses tapered nuts, but shoulder nuts would probably be ok (T shaped if you look at it from the side)
Alleycats can be fitted with offcentre taper nuts to make 4x98 rims fit 4x100.
*n
Mr K
I reckon 1mm isn't going to make much difference. It'll stretch each stud or nut by 0.25mm which isn't much. I probably wouldn't do it if the wheel uses tapered nuts, but shoulder nuts would probably be ok (T shaped if you look at it from the side) surly it would be 0.5mm???
Mike D
Club RR Member Number: 57
4" pcd is 101.6mm
i'm sure you could make them fit, but i wouldnt do it. i unknowingly had some 4x100 pcd on a mini and going round a corner two of the wheel studs sheared.. never again.....
MWF
As penski has said, off center nuts.
том
"If in doubt, flat out!"
"OFFSET (also referred to as 'ET'):
Your car requires a unique offset. Simply this is where the outside of the wheel needs to be in relation to the bodyline of the vehicle, [glow=red,2,300]realistically you can go 5-7mm outside these recommendations[/glow], but always consult a technician if you are unsure, as there are often other factors that need to be considered.oops
Last Edit: Jan 9, 2006 18:14:12 GMT by том
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
TommyG, the matter in question in the PCD, not the offset
Not concerned about offset at the mo.... it's the stud pattern etc. that's the headache!
seeing as its four stud to four stud can you not have the drums/discs redrilled to 4x100? There should be plenty of surface face to fit both the 4x101 and the 4x100. With the PCD being so close its a bit of a bunch of ar5e, but if it were me i wouldnt take the chance.
slater
Club RR Member Number: 78
If they use sleeve nuts ( the T shaped ones) then if you can get it to fit it should be safe. you could enlarge the holes in the wheels by 0.5mm if you cant get it to fit but they may have enough clearance allredy.
If they use taper nuts then do not attempt it unless you can get hold of some of the so called 'wobbly' nuts with floating seats.
bo110x. They're all the taper-nut kind.
том
ah yes... thats twice today i've just been really stoopid. sorry still gettin my head round PCD's, et's, spiggots etc... still learning
They'll fit if you weld them on.... ;D
surly it would be 0.5mm??? That's true, but I am brain damaged and can't count.
I've run BMW wheels on a Viva without a problem but V8Mike's post above seems to outrank me.
Metric-ising old imperial measurements (4.5"=114.3, 3.75"=95.25mm, 5.5"=139.7 - all common 'modern' pcds) is where most of these wierd mm pcd measurements come from. The problem with 100mm/4" is that whilst they're are close, they're not just the same figure in different units. It will vary from wheel to wheel...I'd say try it, but err on the side of caution.
impmann
Overcoming stupidity is the greatest challenge left to mankind
NEVER EVER BLOODY EVER try to stretch metric stud patterns onto Imperial ones. 100mm pcd is NOT close enough.
I've been to the inquest that followed the death of a college mate that died as a result of fitting 100mm pcd rims onto his Imp (4inch pcd). Its not big, its not clever and it doesn't work.
If you want rims for your Minor look at Midgets, Vivas (*not Chuvvitts*), Imps and Minors.
Your life is worth more than a set of rims, dude.
1964 Hillman Imp 1976 Hillman Imp 1967 Hillman Imp (And a few projects dotted around the country)
Just cos something is good for you doesn't mean its good for everyone - for example Marmite does not make good Dog Food.
NEVER EVER BLOODY EVER try to stretch metric stud patterns onto Imperial ones. 100mm pcd is NOT close enough. I've been to the inquest that followed the death of a college mate that died as a result of fitting 100mm pcd rims onto his Imp (4inch pcd). Its not big, its not clever and it doesn't work. If you want rims for your Minor look at Midgets, Vivas (*not Chuvvitts*), Imps and Minors. Your life is worth more than a set of rims, dude. Debate over. They don't fit.
