Dec 14, 2009 15:08:59 GMT
evening, just thought id ask opinions!
my mk5 1.6 tina, wont play ball in the cold, or when its been left for long enough for it to completley cool down, itl crank over no problems, and will spluter but not fire completly. however with a bump itl go pretty much straight away, ive checked the obvious plugs n leads etc and they all seem alright, once its running it runs mint, and can be turned of and fired back over without any hastle.
ballast resistor comes 2 mind? can i bypas this by a wire from battery to coil just to get it fired up (obviously take the wire of once its running)
all opinions welcome before i spend a nite ar5ing around tryin 2 find out the problem!
Dec 14, 2009 15:59:03 GMT
Won't be the ballast... that only gets used while the engine is running, while it's cranking it's on a straight 12v feed ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Poor cold starting is a symptom of *something* but it could be a few things. I'd be changing the plugs (they can look alright but be worn out) checking the timing (points, condensor) and looking really closely at the coil HT terminal, the leads and the distributor cap in the dark with the engine running. It's often HT tracking to earth robbing your spark so the plugs can't fire the cold, dense starting mixture. After all of that, I'd be into the carb next, but TBH even if it is a VV they usually start ok ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Dec 14, 2009 16:02:30 GMT
ahhh, ballast resistor was just an idea! il do the new leads, plugs,rotor arm and cap route, hope that this mite solve the problem!
93fxdl
Enter your message here...
Dec 14, 2009 16:23:11 GMT
even when the pinto was new they could be a bit temperamental starting from cold. the way i get my transit to fire up from cold is two stamps on the loud pedal to pump a bit of juice in then it fires straight up. hope this helps ttfn glenn
Dec 14, 2009 16:26:59 GMT
i tried that one 2 my cost, it didnt fire up, pumped pedal a few times, pushed it and when i bumped it, it backfired with such force its blown the seam away from the backbox, sounds mint now anyway
Dec 14, 2009 16:27:31 GMT
If it bumps easily but wont fire on the key its normally a lack of electrical power at the spark plug due to the drain of the starter motor, that can be caused by pretty much any part of the ignition system, or even a weak battery, i'd try a newish battery off something else on it (or even jump leads from a running car) before buying lots of stuff.
Dec 14, 2009 17:43:43 GMT
Make sure those points are opening nice and wide and closing properly and they're clean.
Out of routine I normally replace all the plugs, leads, cap and condensor for new so I know I've got good reliable stuff on there.
Dec 14, 2009 17:52:09 GMT
Make sure those points are opening nice and wide and closing properly and they're clean. my 1st thought too pinto points can get very coroded, and yet still look okay and then check dizzy cap for tracking you could always get some of this.............
Dec 14, 2009 18:28:16 GMT
Also if your still on the VV carb I'd advise to get shut and find a 32/36 dgav, preferably with a manual choke ![;)](//storage.proboards.com/forum/images/smiley/wink.png) I have never had anything but trouble from VV carbs so if I ever get a pinto with one its the first thing in the bin! Good luck ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
bortaf
Dec 14, 2009 19:18:07 GMT
evening, just thought id ask opinions! my mk5 1.6 tina, wont play ball in the cold, or when its been left for long enough for it to completley cool down, itl crank over no problems, and will spluter but not fire completly. however with a bump itl go pretty much straight away, ive checked the obvious plugs n leads etc and they all seem alright, once its running it runs mint, and can be turned of and fired back over without any hastle. ballast resistor comes 2 mind? can I bypas this by a wire from battery to coil just to get it fired up (obviously take the wire of once its running) all opinions welcome before I spend a nite ar5ing around tryin 2 find out the problem! If it starts sopt on with a bump first thing id check is the 12V boost wire on the starter it could have come off, or somone has fitted an EFi starter which doesnt have the extra post. Alternativly the starter could be on the way out and drawing so much current that theres not enough left for an extra fat spark thats needed when its cold ? Get a volt meter on the coil live and get somone to crank the engine over, it should jump from 9 V to 11 or 12 whilst cranking. After that id go with the other suggestions already posted ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Last Edit: Dec 14, 2009 19:20:55 GMT by bortaf
R.I.P photobucket
all sujestions have been noted! tonight ive changed leads, and replaced (a very worn looking!) cap, and put the battery on charge to make sure its fully topped up.
we shall see what 2moro's cold morning brings
il try the other sujestions if this hasnt worked
