Bought a set of heavy duty rubber bushes for the front TCA arms, the outer ones ( what the anti-rollbar goes through),...... bloke in the shop tells me all sierra ones are the same, but they look quite a bit smaller than the hole in the TCA arm? Am I being a ficko? or is there more than one size? Thanks
ILIKELURKINGME
Not 100% sure (it's been years since I fitted any) but do they not increase in diameter when you tighten the anti-roll bar nut up?
onlyrwd
'78 Cavalier 4 door / '78 Manta Berlinetta
Never known any different sizes, unless he has given you Escort ones by mistake, mind you they may be the same size too.. best checking..
Mick Gradually trying to own one of everything
XR4X4 have differnt track control arms not sure about the anti roll bar bushes though.
You got any pictures?
MMmmm..glad its not me missing the obvious then! Unfortunately I'm at work at the moment, will gets some pics first thing in the morning Where's that Dom when you need him..... loads of useless information when you don't need it, then nowhere to be seen when you do ;D Thanks
ILIKELURKINGME
MWF
They should all be the same, it's only the roll bar thickness which differs as far as I know.
When I fitted them I really had to cram them in.
Job done! Not too bad to do in the end, the bushes were right, just looked wrong when not fitted.Perhaps I was being ficko after all ;D Cheers
ILIKELURKINGME
Job done! Not too bad to do in the end, the bushes were right, just looked wrong when not fitted.Perhaps I was being ficko after all ;D Cheers Another one of your (Strawberry) Blonde Moments ;D
paul4be
'86 Capri Laser, Frontera 4x4
Just for info, all Sierra outer TCA bushes are the same. Inner bushes differ between normal 2wd (10mm bolt) and Cossie/xr4x4 versions(12mm bolt).
