okai i picked this up today and found: The passenger footwell full of water while the drivers side one damp...
AND
i seem to have a problem starting it......it doesna start!!!!!
i have tried jumping starting, replaceing the battery, hitting the starter with a big hammer. tried bump starting it at 50 (this worked for 4 secs, as soon as i hit the clutch to change gear it stalled and wouldn't bump start again)
the lights on the dash do not go dull when trying to crank it over as it will not crank over. It just had the timing belt done at 61000 mile (only 67000 on the clock)
there is a pic if we can get to the bottom of this problem.
thanks in advance.
please inbox me the answer as this thread will be locked/deleted thanks
Current Fleet: 2004 Audi A4 1.9tdi Sport Avant 2014 Ford Fiesta 1.25 (wifes car, curse word box) 1987 Volkswagen Polo CL
v8ade
Is there an earth on the engine or possible ecu faulty
V8 on open headers at full throttle "Heaven"
Jaguar xf SportBrake rover 820 Turbo vitesse
edit - cos I read the OP properly this time.
I'd suspect the wiring to the starter and the ignition switch if the lights don't dim when you try to start it.
Last Edit: Dec 2, 2009 17:11:48 GMT by jrevillug
What reg is this? It sounds like the immobiliser has thrown its teddy out as that will give you everything except starting. If you have a key fob then disconnect the car battery, give it a few hours, reconnect then press the left hand button on the fob four times near the dashboard - this should wake the system up. I've had to do it to my boy's 'Tro and my R200 before.
Last Edit: Dec 2, 2009 17:29:17 GMT by marinanut
Rover Metro - The TARDIS - brake problems.....Stored Rover 75 - Barge MGZTT Cdti 160+ - Winter Hack and Audi botherer... MGF - The Golden Shot...Stored Project Minion........ Can you see the theme?
jump lead direct from the battery to the starter motor will get it to spin over, if it starts its the imobiliser playing up.
okai. it is the 1996 model. 1.4 rover engine twin cam..dunno if it makes much difference but it has 3 different keys and two fobs.
while they sort that, do you have a sunroof? probably needs sealed
alexg
Most probably imobilisor as said. Flooding probably caused by drainage channel running from under the front screen, maybe blocked with leaves etc. Seen this a few times
1979 'V' Austin Allegro Estate
1990 'G' Rover Metro GTI 1.8 VVC
1985 Sinclair C5
right i have her running from a bump.....but not from the key so now the car is stuck at the bottom on me drive 100yards away and slighty intruding on the main road.......reallli need some help on getting this starter to wwork temporly for like 5 mins to i get to start
as i said, clip a jump lead on the positive termianl of the starter, switch the ignition on and then touch the other end of the lead to the positive battery terminal, it'll start and run then even if the imobiliser is still on.
bortaf
Right, make sure the ign is OFF and it's OUT of GEAR, run a small wire from the posative battery terminal to the small terminal on the starter motor, if it turns over the starter is fine, if it doesn't and you have checked all the earths and live like said to do earlyer then you 99% need a new starter or solenoid, if it does turn over either the immobiliser is stuck on or the ignition switch or wiring is at fault, if it's stuck why not bump start it again and drive it back to where you want it
R.I.P photobucket
as I said, clip a jump lead on the positive termianl of the starter, switch the ignition on and then touch the other end of the lead to the positive battery terminal, it'll start and run then even if the imobiliser is still on. Why not try what popup's already suggested TWICE?? It's probably your best bet! Failing that, stop buying really random (seemingly perpetually broken) cars and stick with one!
