I have decided to sell the current heads pistons rods and crank from my estates engine as I am about to fit a new 347ci stroker kit and the current parts will no longer be compatible . engine has only done 2000miles since build so all parts are in A1 condition . parts are as follows : I have a set of trickflow twisted wedge heads with pushrods and stud girdle £1000 ovno trickflow tall alloy valve covers with billet trickflow filler £100 trickflow forged twisted wedge 4.030 pistons with speed pro plasma molly rings on scat rods with milodon rod bolts SOLD Pete Jackson steel timing gears SOLDsome pics of the heads , the only parts that will not be included are the roller rockers
Last Edit: Dec 3, 2009 18:17:32 GMT by Deleted
spec of heads as follows : Brand Trick Flow Specialties Manufacturer's Part Number TFS-51400010 Part Type Cylinder Heads Product Line Trick Flow® Twisted Wedge® Track Heat® 170 Cylinder Heads for Small Block Ford Summit Racing Part Number TFS-51400010 Cylinder Head Style Assembled Cylinder Head Material Aluminum Cylinder Head Finish Natural Combustion Chamber Volume (cc) 61 CNC-Machined Combustion Chamber No Intake Runner Volume (cc) 170cc Exhaust Runner Volume (cc) 66cc CNC-Machined Intake Runner No CNC-Machined Exhaust Runner No Combustion Chamber Style Heart Intake Port Location Standard Exhaust Port Shape Square Exhaust Port Location Standard Intake Valves Included Yes Intake Valve Diameter (in) 2.020 in. Exhaust Valves Included Yes Exhaust Valve Diameter (in) 1.600 in. Valve Springs Included Yes Maximum Valve Lift (in) 0.600 in. Outside Diameter of Outer Spring (in) 1.460 in. Damper Spring Included Yes Number of Springs Per Valve Dual Retainers Included Yes Retainer Material Chromemoly steel Locks Included Yes Lock Style 10 degree Valve Stem Seals Included Yes Valve Stem Seal Style Viton® fluoroelastomer Rocker Arm Studs Included Yes Rocker Arm Nut Thread Size 7/16-20 in. Rocker Arms Included No Rocker Arm Nuts Included No Guideplates Included Yes Guideplate Pushrod Size 5/16 in. Accessory Bolt Holes Drilled Yes Intake Valve Angle 15 Exhaust Valve Angle 17 Valve Guides Included Yes Valve Guide Material Manganese bronze Valve Seats Machined Yes Valve Seat Machine Style 3-angle Valve Seat Material Tungsten Steam Holes Drilled No Oiling Style Through pushrod Machined for O-Ring No Heat Crossover No
B-8-D
down to one car!!
theres a wanted add on eurodragster asking for sbf heads.. si
theres a wanted add on eurodragster asking for sbf heads.. si cheer's dude i'll give it a go
v8ian
Mark, why now, I have just spent a fortune on upgrading my Rover engine to run 11s, so now you start selling bits to get me into the 10s, curse word
nice spec but why is the degree wheel on the cam and not the crank
nice spec but why is the degree wheel on the cam and not the crank [/quote]yeah probably not the best pic to use really i put it in the wrong place to start with and that's when i happened to take the pic . that said putting it on the crank on a v8 is a pain as the crank sticks out way to far making it awkward to fit the pointer
10mpg
Club RR Member Number: 204
Stuck these on the mustang owners club forum for ya..
some of the parts now sold
