racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
Dec 28, 2005 16:01:56 GMT
why does my car hate me? well last night taking my girlfiend home, the car started and ran sweet. 3 mins down the road it started making a sound i can only describe as tin cans being dragged behind a car for about 3 seconds then it died. My dad towed me home and this morning i pulled the engine out and stripped it to find; number 2 so from what i can see its detted! the mystery is the engine has been running rich, it was a sub zero night and the engine was warming up. there was no indication (pinking ect) and it ran beautifully all day untill that point. when it died it was at very low throttle opening (so no load) and low RPM. it has also killed the top ring in 2 and 4. any suggestions why this may have happened? i need a +0.060" piston and a set of rings minimum everything else including the head and bores are mint (lucky) i need it on the road by the 6th latest, so suggestions of suppliers, spares, bits, engines all welcom. Anyone who tell me to put a pinto in it gets a slap! ;D
Dec 28, 2005 16:03:26 GMT
CA18DET
Dec 28, 2005 16:05:35 GMT
..... and this morning i pulled the engine out As you do when it's minus figures outdoors. I couldna find the motivation to fix yesterday's snapped exhaust on my landy this morning... christ do you NEVER take a day off!? Stop showing us up! ;D
racer86
Dec 28, 2005 16:06:52 GMT
CA18DET in 9 days (of which 2 I'm working) and i don't even have the engine yet? even I'm not that quick! (though i appreciate your faith) and if your going to do that it would be just rude not to SR20 it!
Last Edit: Dec 28, 2005 16:11:06 GMT by racer86
Dec 28, 2005 16:12:53 GMT
Hopefully someone will come up trumps with some kind of pistonage...
Are you bringing it back to Swansea?
ive blown my engine up!! DarrenW
@darrenw
Club Retro Rides Member 74
Dec 28, 2005 16:13:43 GMT
Oh No! But, see, THIS is why you're such a forum GOD: last night taking my girlfiend home then this morning i pulled the engine out and stripped it See, it's taken me six months just to WASH my Golf! And three of those were spent wondering where I'd left the keys!
racer86
Dec 28, 2005 16:15:51 GMT
Are you bringing it back to Swansea? Ill tell you in 9 days but hopefully i will.
Dec 28, 2005 16:25:45 GMT
that a curse word. Vauxhall reliability
impmann
Overcoming stupidity is the greatest challenge left to mankind
Dec 28, 2005 16:46:53 GMT
Check your carb. In the Imp world we are seeing a lot of carbs jettisoning the tiny screws that hold the throttle butterfly onto its spindle... that causes very similar damage. Such as this: Hope that helps - and good luck finding the pistons/bits to fix it.
1964 Hillman Imp 1976 Hillman Imp 1967 Hillman Imp (And a few projects dotted around the country)
Just cos something is good for you doesn't mean its good for everyone - for example Marmite does not make good Dog Food.
Dec 28, 2005 16:50:39 GMT
Sorry to hear that Sure you'll get it sorted mine. Something get sucked into the engine? Anything wedged in the piston head/rings? On a note, I was outside in -2 today working on the car for 2 hours, changing needles and trying to quell a fuel leak (pouring out the bellmouths, lol!). Found out float needles are shot. Do I have them? Hell no! ;D
racer86
Dec 28, 2005 16:54:38 GMT
checked the carb and all is well, I'm 99.9999% sure it was caused by detonation but i cant understand why when it was rich, cold and under no load. on further inspection it looks like the ring has stuck on number 2 but i cant see why this would have caused this?
Dec 28, 2005 16:57:42 GMT
Hmmmmm its right around where the squish is on those pistons isnt it? What did malcom say about things like this? It dosent have to run very lean, only into the condition where the engine is under load, and the burning is at its hottest, i.e. just under stoich. In these conditions the air is a lot denser mabe there was a little too much O2 and not enough fuel when giving it some?
Would have had to lose a lot of screws to do three pistons like that! Ill give steve a ring see if he has any of his chevette bits hanging around, i know hes still got his chevette. Super duper mega harsh mate, you can have the engine out of my new imp, but i don't think it would be much use!
Good luck in getting it fixed
J
racer86
Dec 28, 2005 17:24:06 GMT
Hmmmmm its right around where the squish is on those pistons isnt it? What did malcom say about things like this? It dosent have to run very lean, only into the condition where the engine is under load, and the burning is at its hottest, i.e. just under stoich. In these conditions the air is a lot denser mabe there was a little too much O2 and not enough fuel when giving it some? yes this is true but, there was no load on the engine, the mixture was well rich ie still on choak and its too rich anyway. The engine was still warming up. the only thing i can think of is that glowing carbon build up ignited the mixture.
impmann
Dec 28, 2005 17:46:42 GMT
You'd have to have a massive comp ratio to do that damage with a rich mixture.
Is this on all four pots or just the one?
impmann
Dec 28, 2005 17:47:52 GMT
Suggestion: Blydenstein?
Dec 28, 2005 17:50:58 GMT
Very true, i recon show it to him and hesd know exactly what went wrong!
J
racer86
Dec 28, 2005 17:51:29 GMT
compression ratio is 11:1, it was happening on 1,2 and 3 the worst and very slightly on 4.
slater
Club RR Member Number: 78
ive blown my engine up!! slater
@slater
Club Retro Rides Member 78
Dec 28, 2005 18:09:31 GMT
Very weird, cant work that out and ive seen loads of melted pistons! never seen one like that.
Could it be that the ring broke and caused the problem rather than it being caused by detionation? it just looks like problem originated at the ring groove. Still the marking on the piston CROWNs fits with it going lean at some point. deosent amke much sence.
id check the carb and dizzy before you run it again tho.
Edit: 11:1 on 95 unleaded? living very dangerously there!
Last Edit: Dec 28, 2005 18:11:31 GMT by slater
Dec 28, 2005 18:11:02 GMT
2001 HONDA CT110 (NOT RCV)
Dec 28, 2005 18:12:32 GMT
Rob - 1.3 lump out of a Nova?
If you were further north, you could have had my 1256 until the end of jan...It's SORN atm as I'm swamped with work and can't go anywhere.
*n
