Matty
Nov 19, 2009 21:40:43 GMT
Had this since the summer now - bought with a blown 1.8GL motor, got a donor 8v gti engine, and just in the (slow) process of getting it all fitted, wired up and sorted It's running on coilies and 13x5.5J weller steels, and has a vw factory tow bar, and headlamp washers too! 8) Mint grey interior with 60/40 rear bench To do list: Source and fit a pair of gti driveshafts - anyone? Source and fit an alternator Bypass the ISV Fit and wire in the lift pump and fuel pump Connect the exhaust up to the downpipe Buy and fit a throttle cable Fit front bumper and bonnet DRIVE! Probabaly missed loads - but here's a teaser photo ;D Bit of a tight fit!
Last Edit: Nov 23, 2009 12:49:10 GMT by rmad
Nov 19, 2009 22:41:50 GMT
why are you going to bypass the ISV?
I know its not stricktly needed and expensive new but they are available used cheaply and can quite often be fixed by cleaning.
Matty
Nov 19, 2009 22:59:37 GMT
Mainly because my budget is so small, and i don't have an ISV, my donor engine didn't come with it, so to avoid buying off eBay and not knowing the condition of an ISV, it seems easy to just bypass it, the americans seem to do it with little effect, I may just have issues with idle on cold starts, and if so - i'll buy one
If you have both gearboxes you don't need GTi driveshafts. You can swap the 90mm drive flanges for the 100mm ones, it's not a difficult job, there's a guide on how to do it online
Matty
ooh really? Ideal! Any idea where the guide is? I'll have a crack at that tomorow cheers!
dubbed
Kool mk2 I'm running a mk2 on 13X8j et0 wellers... i'll get some pics up soon
Patience is a virtue....
Nov 21, 2009 10:52:09 GMT
yeah don't you have to lock the drive flange bit and undo the centre bolt and retract them? seem to remember it going something like that on a polo..... pretty sure its in the haynes manuals too
Nov 21, 2009 11:23:13 GMT
more pics matty,more pics!!
300ce lowrider c220 track car c280 youngtimer S320 ...vip no 4 S430 .. 2 x slk 230 500se , E36 amg E 430 E55 amg Ml 320 C43 amg
Matty
Nov 21, 2009 15:58:02 GMT
I'll get some decent photos when it's back on all 4 wheels, with driveshafts and fuel pumps fitted Roll it out of the lock up and give it a damn good wash!! But here's one, just to keep you happy
Last Edit: Nov 21, 2009 16:17:11 GMT by Matty
Matty
Dec 14, 2009 20:21:02 GMT
Nice interior.
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
