Jan 23, 2010 14:44:29 GMT
New headlights look far cooler! And the chequered bonnet bit looks good, different Just buy a second set of standard springs, and cut yours to get it slammed (i cut 3 coils from my front springs, and 2 from the backs) Then when it comes to registering the car, swap the second set of standard springs in = stock height! It'll take a few hours work, but worth it imho! Good luck! Sounds strict, I like the British laws, goes through an MOT with cable ties holding them up so they don't drop when they raise the car hehe, score
yzn
Jan 24, 2010 16:44:06 GMT
New headlights look far cooler! And the chequered bonnet bit looks good, different Just buy a second set of standard springs, and cut yours to get it slammed (i cut 3 coils from my front springs, and 2 from the backs) Then when it comes to registering the car, swap the second set of standard springs in = stock height! It'll take a few hours work, but worth it imho! Good luck! nice idea but iam thinking 2 coils front and 1 from the back and if it need more low will cut more with 15" rims similar to these or bmw e34 rims
yzn
Jan 27, 2010 13:27:03 GMT
went today to the garage and we manged to take out the springs and cut them after 2 hours, we cut 3 coils from the front and 2 coils from the back and i'm very pleased with the result i have been cruising around for an hour B-) sorry for the bad pictures,i will take a better ones later its so cold outside
Jan 27, 2010 13:58:32 GMT
thats a win right there!!
Jan 27, 2010 14:14:22 GMT
That looks excellent!
Lawsy
Jan 27, 2010 14:49:41 GMT
perfect ride height - love it
Jan 27, 2010 16:03:16 GMT
Excellent stuff
Jan 27, 2010 16:14:38 GMT
Regarding the wheels, I assume you know that the BMW wheels are 5x120 PCD whereas your Benz is 5x112? Also the BMW may have a smaller centre-bore - Mercs have 67.5mm which is rather big. I'm not sure if wobble bolts could absorb 8mm difference in PCD or not. It may be easier to find some wheels in the right PCD as the offset will probably be more suitable too. Keep up the good work!
Jan 27, 2010 17:04:17 GMT
As BenzBoy says, E34 wheels would probably not fit. You could have them re-drilled to suit but considering the centre bore of the wheels is quite large, it might not be possible.
E34s are 5x120, centre bore 72.5mm. ET 13-20
Looks excellent BTW, love it!
markbognor
Club RR Member Number: 56
Jan 27, 2010 20:56:56 GMT
Excellent job sir!
yzn
Jan 27, 2010 22:06:51 GMT
Regarding the wheels, I assume you know that the BMW wheels are 5x120 PCD whereas your Benz is 5x112? Also the BMW may have a smaller centre-bore - Mercs have 67.5mm which is rather big. I'm not sure if wobble bolts could absorb 8mm difference in PCD or not. It may be easier to find some wheels in the right PCD as the offset will probably be more suitable too. Keep up the good work! yeah they don't fit but as whitbytom said they could be drilled but won't do that just not worthy , seen merc with them they don't look right so the new plan is hubcaps and maybe with whitewalls
Jan 28, 2010 10:12:33 GMT
Nice looking benz Rial has made quite a few wire mesh style wheels that fits mercedes
yzn
Jan 28, 2010 17:03:28 GMT
raised the catalyst today but it still scraping on speed bumps need another idea to sort this !?
yzn
Jan 28, 2010 17:06:33 GMT
*sorry for double post
Last Edit: Jan 28, 2010 17:11:17 GMT by yzn
Jan 28, 2010 17:25:55 GMT
Nice ride always wanted that shape, never one around when I had the money, keep up the good work.
Jan 28, 2010 18:53:34 GMT
raised the catalyst today but it still scraping on speed bumps need another idea to sort this !? Is it scraping badly? Very low cars often scrape to some extent - my Benz's downpipe would scrape going over speedbumps. I just drove very slowly over them! I can understand your concern though, cats aren't exactly cheap if it gets broken.
maxlee
cat gard made of sum metal to take the scrapping maybe? dose look loads better with them lights.. liking the bonnet as well
Last Edit: Jan 30, 2010 1:35:08 GMT by maxlee
yzn
One thing that improves the looks is if you paint the plastics inside the headlamps satin black.
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
qwerty
Club RR Member Number: 52
Well that looks flipping ace and now has me searching ebay for one haha.
