Hopefully someone on here can help...?
I recently had my MX-5 roof replaced and upgraded from a plastic rear window to a heated glass one. I've got most of the bits for connecting up the heated element (switch, relay, fuse), but need some advice on choosing the right wire!
This is the kind of thing you're supposed to connect the window to the loom with: www.mx5parts.co.uk/product_info.php/products_id/987
However, firstly the guy who fitted the roof told me that particular harness was no good , and secondly I'm not keen on spending 45 quid on that when a couple of bits of wire and some spade connectors will do the trick!
...but I have no idea what kind of wire I should use. Any advice, anyone?
