The real fast drag cars don't have gearboxes, they rely on a carefully controled lock up clutch powered by air rams. This slips the clutch to transferr as much power to the track as possible on take off, without spinning the wheels. Top fuel cars need rebuilds mainly becuase of oil contamination, nitro has a tendancy to get into the oil and ruin it, once its in the oil it makes it very explosive.
J
Well heres some pretty bonkers facts which were passed onto a friend by a guy called Jerry Gaskill who apparently helped form one of the first drag strips in California 'The Santa Maria Drags'
I'm not sure on the accuracy of the info or how up to date it is - but sure makes for some mind boggling reading
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 6 rows at the Daytona 500.
Under full throttle, a dragster engine consumes 1 gallon of nitromethane per second; a fully loaded 747
consumes jet fuel at the same rate with 25% less
energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger.
With 3000 CFM of air being rammed in by the
supercharger on overdrive, the fuel mixture is compressed into a near- solid form before
ignition.
Cylinders run on the verge of hydraulic lock at full
throttle. At the stoichiometric 1.7:1 air/ fuel mixture for nitromethane the flame front temperature measures 7050 degrees F.
Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder. Spark plug electrodes are totally consumed during a pass.
After ½ way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow. If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. In order to reach 200 mph well before half-track, the launch
acceleration approaches 8Gs. Dragsters reach
over 300 miles per hour before you have completed reading this sentence. Top Fuel Engines turn approximately 540 revolutions from light to light! Including the burnout the engine must only survive 900
revolutions under load. The redline is actually quite high at 9500rpm.It takes 1500+hp just to turn a top fuel blower.
The pressure >coming out of the headers can provide 1000lbs of downforce. When a cylinder goes out, it can actually steer the car due to loss of down force on one side. There is so much torsional twist in the crankshaft (up to 20 degrees at the big end of the track) that sometimes cam lobes are ground offset from front to rear to try and re-phase the valve timing closer to synchronization with the pistons.
The car will be going over 60mph before the rear wheels cross the start line, 300 inches.
The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated US $1,000.00 per second.
The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06 (or blown Viper). Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past
the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster
catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course.
Love this last bit ;D
